How to install the bash prompt
Check for Existing .bash_prompt:
First, you need to check if there's already a .bash_prompt file in your home directory. Execute the following command:
ls ~ -a | grep .bash_prompt
Rename Existing '.bash_prompt':
If you find an existing .bash_prompt and want to keep it as a backup, rename it using:
mv ~/.bash_prompt ~/.bash_prompt_OLD
Download and Move New .bash_prompt:
Download the bash_prompt file from my project post. After downloading, move the file to your home directory and rename it to .bash_prompt:
mv ~/Downloads/bash_prompt ~/.bash_prompt
Update .bashrc:
Now, you need to update your .bashrc file to ensure it uses the new .bash_prompt. Open .bashrc with nano:
nano ~/.bashrc
At the end of the file, add the following line to source the .bash_prompt:
source ~/.bash_prompt
Save the file by pressing Ctrl-S and exit nano with Ctrl-X.
Apply the Changes:
To apply the changes and use the new bash prompt, source your .bashrc file:
source ~/.bashrc
Set A Dark Background:
Visual Studio has a pleasantly dark background that we all love. The hex code for it is: #1F1F1F. Set the color by pressing the button with horizontal lines on it ⟶ Preferences ⟶ Unnamed ⟶ Colours ⟶ Background.
