2017-04-20-1100PM.xlsxAn Excel sheet with the same data as is in the text file of the same name below.sheet - 1.12 MB - 04/21/2017 at 19:32 |
2017-04-20-1100PM.txtI left the trap running all night with food inside to try to capture data about the possums living under my deck. It looks like the baby possum (a bit bigger than a hamster right now) was in there several times...I'm hoping to catch him and the Mommaplain - 1.07 MB - 04/21/2017 at 19:22 |
TrapBox Overview.docxAn early document that I plan to expand to cover things in more detail.document - 17.47 kB - 04/19/2017 at 15:13 |
Trap_STL_FILES.zipFiles for the Box, remote and servo mount. The servo mount requires 2 x 1/4" diameter magnets inserted into the 'magnet end' to hold itself to the trap. Hopefully this will be replaced by the solenoid drive in very short order.Zip Archive - 233.63 kB - 04/16/2017 at 16:01 |
Trap_remote_v4.pdfA pdf of the current version of schematic for the Remote. Eagle files are attached here as wellAdobe Portable Document Format - 33.33 kB - 04/15/2017 at 13:18 |
Smart_trap_v6.pdfA pdf of the current version of schematic for the Trap Box. Eagle files are attached here as wellAdobe Portable Document Format - 34.71 kB - 04/15/2017 at 13:18 |
Trap_logger1.pyPython script that will log data from the trap when connected to the USART Port on the remote. The '/dev/tty.usbserial-A602SF0Z' would need to be replaced by COMx or whatever port the FDTI module shows up as on your machinex-python-script - 2.78 kB - 04/15/2017 at 12:16 |
Trap_remote_v4.brdRemote_PRX_V4brd - 96.68 kB - 04/15/2017 at 00:04 |
Trap_remote_v4.schRemote_PRX_V4sch - 368.86 kB - 04/15/2017 at 00:04 |
Smart_trap_v6.schTrap_PTX_V6sch - 1007.71 kB - 04/15/2017 at 00:03 |
Smart_trap_v6.brdTrap_TPX_V6brd - 189.32 kB - 04/15/2017 at 00:03 |
