CNC, 12V Power supply 5A, Arduino + Stepper motor shield, Cross table (Ebay 30 €), Wood Frame , Freecad, UGS
JPEG Image - 314.65 kB - 06/30/2019 at 14:01
JPEG Image - 166.66 kB - 07/17/2018 at 14:49
Stepermotor mounted on the proxxon cross table
View all 2 project logs
I think it is better to use Jaw Coupling for the motor coupling, which can withstand greater torque without mechanical deformation and has a longer life. Such as:https://www.motiongoo.com/index.php?route=product/product&path=59_121&product_id=398
It always depends on what you want to pay
(^_^), what you said makes sense.
The foundation of the facility has changed fundamentally.It is a massive wooden construction of 2 parts inserted as a stable foundation.
Many components can be obtained from any hardware store.
Some new pictures will folow
I have got my stepping motors and now I need to make the adjustments to the axes
this would be a real cool think !! I can't wait to see a viedeo !!
Does it work yet? ;)
prabeenraj01
Psy Chip
joekutz
SirDan
Yes, delete it Cancel
You are about to report the project "Miniature CNC milling machine", please tell us the reason.
