Click Link for FULL information and Assembly
The Search for a Reflow Oven OneNote Link
Build a reliable DIY Oven
l
The oven worked perfectly!
Ill add the components and instructions on the description section.
Just received the boom mat, handled with gloves because it has fiberglass, waiting on the gold tape.
Just recieved the Toast-R-Reflow Control Backpack 2 v0.1.1 by Geppetto Electronics here, It looks promising. Also we have a sexy Black n Decker TO1313 oven in the background
I chose the Black Decker TO1313SBD because of it Even Toast Technology. as well as a pcb oven tray.
Getting some insulation supplies
Im going for the Toast-R-Reflow controller + Power kit.
After a hard look at the screen i came up with these choices
The ratings dont look so good for T962, looks like modifications will be needed.
based of whizoo
DIY reflow component kit called ControlLeo2, looks like it uses a black n decker oven, doesn't look too bad at all
Thankfully Google reminded me via ads on youtube to get a Reflow Oven. So far I see some Sky High Prices. The sub 200$ seems decent, ill have to check the reviews.
Ok Great!, I got the Toast-R-Reflow Controller MKII. when will Toast-R-Reflow Power board kit be in stock?
I've just been lazy. I have a new SMD version of it I need to qualify and get inventory in stock. I'll get to that early this week.
If you want to try the modify-a-toaster-oven route, might I humbly point out Toast-R-Reflow? http://hackaday.io/project/3908-toast-r-reflow
