Printable StickVise v4.stlSTL generated from defaults, should be compatible with standard StickVise Dimensions, now has jaws built in.Standard Tesselated Geometry - 678.59 kB - 06/13/2017 at 07:49 |
Printable StickVise v4.scadJaws are now printable also! No need to rely on the external generator, simplified some parts into inches with a function, fixed a spacing bug that showed up for the taller pieces.scad - 5.27 kB - 06/13/2017 at 07:46 |
Printable StickVise v3.stlSTL generated from defaults, should be compatible with standard StickVise Dimensions.Standard Tesselated Geometry - 1.08 MB - 06/11/2017 at 00:15 |
Printable StickVise v3.scadParts rotated to a more printer-friendly orientation, largest bore holes facing upwards to reduce overhangs. Added Extra parameters for spring tensionerscad - 4.54 kB - 06/11/2017 at 00:01 |
Printable StickVise v2.stlSTL generated from defaults, should be compatible with standard StickVise Dimensions.Standard Tesselated Geometry - 1.02 MB - 06/10/2017 at 07:13 |
Printable StickVise v2.scadFully parametric OpenSCAD, make it as big or small as you'd like, change shaft diameters, screw sizes, anything really.scad - 3.73 kB - 06/10/2017 at 07:10 |
Printable StickVise.scadFirst iteration for proof of concept.scad - 2.88 kB - 06/11/2017 at 00:02 |
