Case Blocks - 3Way.stlConnector block with 3 magnetic sides. Not actually used in this design but might be useful for others.Standard Tesselated Geometry - 1.57 MB - 09/22/2017 at 03:12 |
Connector Cable Clip.stlConnector Clip to secure the cables into the enclosure.Standard Tesselated Geometry - 133.68 kB - 07/31/2017 at 05:16 |
Connector Clip.stlConnector Clip to secure Connector on enclosure.Standard Tesselated Geometry - 57.89 kB - 07/27/2017 at 06:03 |
Connector.stlConnector to pass bowden and power cables through the case.Standard Tesselated Geometry - 367.56 kB - 07/27/2017 at 06:02 |
Magnet Cap.stlCap used to glue magnet to acrylic sheet.Standard Tesselated Geometry - 562.58 kB - 07/27/2017 at 06:01 |
Support Bar - Side support (half).stlTwo supports are glued together and the center reinforced with a steel rod.Standard Tesselated Geometry - 28.99 kB - 07/27/2017 at 05:57 |
Support Bar - Top support (half).stlTwo supports are glued together and the center reinforced with a steel rod.Standard Tesselated Geometry - 29.09 kB - 07/27/2017 at 05:57 |
Case Block - Two Magnet.stlCorner support. Glue to one side.Standard Tesselated Geometry - 1.05 MB - 07/27/2017 at 05:55 |
Case Block - One Magnet.stlCorner support. Glued to two sides.Standard Tesselated Geometry - 535.82 kB - 07/27/2017 at 05:54 |
Case Block - No Magnet.stlCorner support. Glued to three sides.Standard Tesselated Geometry - 1.25 kB - 07/27/2017 at 05:54 |
Case Block - Extra Support.stlSide center supportStandard Tesselated Geometry - 1.06 kB - 07/27/2017 at 05:54 |
Case Sides.dxfThe 6 laser cut acrylic pieces which make up the enclosure sides.AutoCAD DXF - 294.43 kB - 07/27/2017 at 05:41 |
