207_Bot1_17400.IGSThis file contains all necessary files for the Silly String shooter. DXF's, STL's and dimensions can be obtained from this file(once each part is individually saved).Initial Graphics Exchange Specification (IGES) - 4.08 MB - 08/10/2017 at 06:33 |
207_Bot1_17100.IGSThis file contains all necessary dimensions for the chassis and each individual part. DXF's can be obtained from this file(once each part is individually saved).Initial Graphics Exchange Specification (IGES) - 6.61 MB - 08/10/2017 at 06:22 |
207_Bot1_17500.IGSThis file contains all necessary dimensions for the wheels. STL's can be obtained from this file once the part is individually saved.Initial Graphics Exchange Specification (IGES) - 7.94 MB - 08/10/2017 at 06:22 |
Adobe Portable Document Format - 506.31 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 345.27 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 108.09 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 356.62 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 69.57 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 148.78 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 149.03 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 75.21 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 178.31 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 166.33 kB - 08/09/2017 at 23:39 |
Adobe Portable Document Format - 143.11 kB - 08/09/2017 at 23:39 |
