Laser Exposer Controller.pdfSchematics for the custom controller.Adobe Portable Document Format - 66.49 kB - 01/29/2019 at 08:44 |
Laser Exposer Diode Driver.pdfSchematic for the diode driver. A resistor has been added to limit max base current in the driver transistor - to avoid frying the opamp if powered up when no diode is connected.Adobe Portable Document Format - 32.96 kB - 01/29/2019 at 08:44 |
