Bluegiga BLE113 module with HM-10/11 firmware = Saving space
A project log for Bionic Yourself V2.0
Project Bionic Yourself (B10N1C) is a small implant for your arm that makes you a bionic-superhero.
txyzinfotxyz.info 09/09/2014 at 14:520 Comments
Mega useful feature of HM10/11 (Bluetooth to serial converter) is remote controlling GPIO pins through AT-style command. I'm going to use this feature for triggering the Reset on Atmega328, which is a requirement for uploading code to Arduino processor.
It should't be a problem with transferring firmware from HM10/11 to BLE113 because they are both based on the same chip CC2541.
