This Telemetry equipment is based on At mega 2560, USB port for serial data and Programming. Currently programming firmware is Arduino, But can be programmed by AVR studio or own firmware. For Communication between FPV and Telemetry receiver i have used APC 220 Long range communication module. For control and display i have used SainSmart 3.2'' LCD with touch. Also for camera gimbal i have included Thumb-sticks. its just the ground station part, The FPV part will be published soon as it will be completed. the Codes will be published later.
Some modifications have been done to project so far.
1- The Thumb sticks have been changed as i used a cheap thumb sticks before, the didn't give good signal (103 POT Resistor malfunction ), this time i'm using sparkfun thumb stick .
2- I also moves the APC220 to new place as hands where causing interference with Signal and transmission.
More stuff will be published as more progress will be made (Sorry working on project on weekends only.)
build yourself a skew planar and clover leaf antennas, you will get better range and less interference
