DIY Telemetry Equipment , Based on AT Mega 2560(upgrade-able to PI ).
Some modifications have been done to project so far.
1- The Thumb sticks have been changed as i used a cheap thumb sticks before, the didn't give good signal (103 POT Resistor malfunction ), this time i'm using sparkfun thumb stick .
2- I also moves the APC220 to new place as hands where causing interference with Signal and transmission.
More stuff will be published as more progress will be made (Sorry working on project on weekends only.)
Thanks for the advise, Project will improve as more progress is been made.
build yourself a skew planar and clover leaf antennas, you will get better range and less interference
