DSC09385.JPGwill cross-cut 8ft sheet material with the use of the outrigger which has but one line of friction along the top of the round pipeJPEG Image - 3.74 MB - 02/04/2018 at 21:48 |
DSC02776.JPGsimple if you think about itJPEG Image - 3.53 MB - 02/04/2018 at 21:47 |
DSC02398.JPGThe jimmy jigs lift off guard, central pivot is automaticJPEG Image - 2.75 MB - 02/04/2018 at 21:44 |
DSC01224.JPGvery simple cross-cut -sled on the Jimmy JigJPEG Image - 3.33 MB - 02/04/2018 at 21:43 |
_DSC8587.JPGJimmy jig in SpanishJPEG Image - 3.15 MB - 02/04/2018 at 21:41 |
_DSC8586.JPGJimmy jig in PortugueseJPEG Image - 5.42 MB - 02/04/2018 at 21:39 |
_DSC8582.JPGjimmy jig in RussianJPEG Image - 3.48 MB - 02/04/2018 at 21:37 |
_DSC8581.JPGunderstanding the jimmy jig in EnglishJPEG Image - 4.00 MB - 02/04/2018 at 21:36 |
_DSC8726.JPGstrong clamp on the jimmy jig's fence/ adjustable with bolts in the t-trackJPEG Image - 2.74 MB - 02/04/2018 at 21:33 |
00004.MTSlift off secondary fencempeg-tts - 33.38 MB - 02/04/2018 at 21:28 |
DSC06769.JPG2 jimmy jig styles one with a circular saw twined with a Bosch table sawJPEG Image - 297.02 kB - 02/03/2018 at 02:23 |
Image015-1.JPGroller hold downs-in's on the fenceJPEG Image - 89.61 kB - 02/03/2018 at 02:22 |
DSC04973.JPGautomatic push block slides on the fenceJPEG Image - 1.81 MB - 02/03/2018 at 02:08 |
DSC07812.JPGsecondary sliding sled, slide on the left end on a telescoped railJPEG Image - 1.70 MB - 02/03/2018 at 02:05 |
00003-001.MTSlift of the secondary fencempeg-tts - 34.97 MB - 02/03/2018 at 02:01 |
DSC06739-001.JPGcheapie sliding sledJPEG Image - 304.72 kB - 02/03/2018 at 01:44 |
Image011.JPGadd this with a router in the apertureJPEG Image - 695.09 kB - 02/03/2018 at 01:43 |
DSC03235.JPGThe forty ninnerJPEG Image - 2.19 MB - 02/03/2018 at 01:41 |
DSC04974.JPGthe on the fence pusherJPEG Image - 2.08 MB - 02/03/2018 at 01:40 |
DSC01727.JPGhow to expand a table saw rip width from zero to 49in.JPEG Image - 2.80 MB - 02/03/2018 at 01:37 |
DSC02413.JPGvery simple but very effective cuts to 4ft on centreJPEG Image - 2.34 MB - 02/03/2018 at 01:35 |
DSC03812.JPGsays it allJPEG Image - 3.69 MB - 02/03/2018 at 01:34 |
DSC04697.JPGread itJPEG Image - 739.55 kB - 02/03/2018 at 01:32 |
00003.MTSthe saw blade zero clearance insert slides under the stationary fence allowing the blade close contact with the fencempeg-tts - 34.88 MB - 02/03/2018 at 01:26 |
00004-001.MTSThe Original from 1980mpeg-tts - 46.59 MB - 02/03/2018 at 01:11 |
00002-001.MTSthe copy by the BIG BOUYSmpeg-tts - 18.38 MB - 02/03/2018 at 00:37 |
DSC05884.JPGmore of the BIG BOUYS, easy to see macduff's inventionJPEG Image - 1.64 MB - 02/02/2018 at 23:53 |
DSC05878.JPGthis is a copy by the BIG BouysJPEG Image - 2.15 MB - 02/02/2018 at 23:51 |
DSC05577.JPGthe original concept born 1980JPEG Image - 2.41 MB - 02/02/2018 at 23:50 |
DSC04701.JPGHow to rip on the jimmy jigJPEG Image - 798.36 kB - 02/02/2018 at 23:47 |
DSC02400.JPGThe lift off guard and see through with splitter that follows the curve of the bladeimage/jpeg - 2.39 MB - 02/02/2018 at 23:44 |
DSC04700.JPGHow it works on top of and existing table sawimage/jpeg - 900.37 kB - 02/02/2018 at 23:30 |
