Become a member to follow this project and don't miss any updates
Tiny robot family
A family of tiny robots, each with their own way of life.
This project is in this list
Browse all lists »
This project was created on 03/22/2014 and last updated 5 months ago.
Description
This is my growing family of tiny robots based on ATtiny controllers, pager motors and photo-transistors.
Details
These three little autonomous vehicles have a lot of similarities such as controller, battery and movement mechanism, and they all percieve the world through photo-transistor eyes. But they are all distinct designs with different capabilities and behaviors. They are the first members of a growing family of miniature robots that I have been playing with off and on for a long time
A key aspect of their design is at least one photo-transistor eye and one controlled LED. This allows them to interact in a meaningful way. Depending on how they are programmed, this could be as complex as data transmission between bots or as simple as interfering with the sight of other bots. The resulting interaction would also depend on the type of bots. For example, the eyes of robot 1 point downward to scan the surface, while robot 3 only looks forward.
At this point I have not programmed them for any complex interaction. Their main behavioral features are thus:
  • Robot 1 - Has left and right eyes looking down. Can detect lightness patterns on the ground. Here is a video of it acting as a line follower.
  • Robot 2 - Has one downward eye and one forward. Controlls a group of LEDs around its perimiter. It can see the lightness of the ground and look forward. It can also signal in all directions with the LEDs.
  • Robot 3 - Has one eye looking forward and two separately controlled LEDs pointing about 45 degrees to either side. It is supposed to be able to detect obstacles and determine which direction to turn to avoid them. I am still developing this feature.
The hardware:
The controller could be any of the 8-pin ATtinys. I have used the tiny85 because that's what I had on hand. I have considered a version based on the ATtiny10, but haven't gotten around to that. The batteries are LIR2032 rechargeable lithium coin cells that I pulled out of some solar key chain lights from the 100yen shop(dollar store). They don't last very long between charges, but I'm not planning on spending much money for fancy new batteries.
Here is the underside of each one.
You can see the 2N7002K mosfet transistors for driving the motors. There are also various resistors, capacitors and LEDs. The schematics are here:
The software:
At this point, the software is very simple, but it is easy to add another behavioral pattern in the code since the main loop simply calls a behavior function. Robot 1 has a line following bahavior. Robot 2 scans the ground and can signal to other robots in the area. Robot 3 avoids obstacles(still working on that one). I would be willing to upload the current code if requested, but since it is continually changing and far from complete, I won't put it here just yet.
If I make new robots, videos, changes etc. I will post a log here about it.
Components
  • 1 × ATtiny85 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 2 × 2N7002K MOSFET Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 2 × small motors from andromedabots
  • 1 × some red LEDs
  • 1 × some ASDL-6620 phototransistors
  • 1 × various smd resistors and capacitors see the schematics
  • 1 × LIR2032 3.6V rechargeable battery
Project logs
View all 2 project logs
Coye Knoll wrote a month ago null point
radioshacks zip zaps those tiny remote control carsuse the same types of motors. u can buy like just the motors,
Are you sure? [yes] / [no]
Mr. Spriggs wrote a month ago null point
Hey,
I dug through the data sheet and came up with a low power version. It works just the same as you original but the ATtiny uses less than half the power the original used.
shlonkin wrote a month ago null point
Cool. Are you shutting down parts of the controller between sensor readings? I'm sure the vast majority of the power is consumed by the motors, so the benefit may be small in the end. But don't let that discourage you from tinkering with it!
Shlonkin,
So after a whole bunch of testing I finally got the tiny robot working. It was so simple I could kick myself. The problem is with the code. The ledon and the ledoff are swapped. When the led should be on like getting sensor data it off.
I replaced the #defines with
#define ledoff PORTB &= ~(1 << 4)
#define ledon PORTB |= (1 << 4)
And now it works great.
The problem was right there all along I wired the emitter and collector backwards. Thanks for the help.
Hey Shlonkin,
So I basically built a copy of your first robot. Then dumped the hex onto the 85. I had no luck getting the great results you have on your video. I played with the setting over and over with no luck. Mine seems to see lines that are not there. I even went and added some sleep mode code to minimize the noise when its reading the sensors.
Any insight?
Here is something you could try. Check the sensor voltage directly with a meter while on a white surface then on black. There should be a significant difference in voltage between them, like around half of your battery voltage in difference. This should be true for both sensors. If you have that, then it is likely a software issue. You are running at 8MHz, right? Try the default sensitivity of 3.
If you are not getting sufficient voltage difference, try changing the resistance value in the sensor circuit. It could be too high or too low.
Mr. Spriggs wrote 2 months ago null point
I built basically a copy of your Robot 1. Im planning on giving it to my nephew as a X-mas. I was wondering are you running it a 8 MHz or 1 Mhz
Thanks
shlonkin wrote 2 months ago null point
I was running it at 8MHz. It would work fine at 1MHz, but you'd want to change some of the numbers in the code to compensate for the slower clock.
DayDreamingPhd wrote 6 months ago null point
I'v been looking at an old 1920 valve amp radio & loking to buy 1 to rebuild & stil keep the valves make it into annolg to digital & if I could get a few people helping m,e this would be grate fun , I have no exspeerence in elictronics & programing. but this would make progject to be on www.kickstater.com .
bootdsc wrote 6 months ago null point
Looks like someone found an old BEAM robotics article and decided to pass it off as there own.
shlonkin wrote 6 months ago null point
Not really, though they do look kind of similar. I've never seen a BEAM bot with a microcontroller, but then again I've never read a BEAM robotics article.
ZaidPirwani wrote 6 months ago null point
well, here is what I did yesterday...
https://github.com/Ejaad/tiny85Bots
That's a really cool robot! How well does it work? Do you have a video of it?
I really like your idea of glue stick wheels, but I'm guessing that thing goes way fast.
Eric wrote 6 months ago null point
Saw this on sparkfun today and immediately thought of the robot family: essential sensor kit https://www.sparkfun.com/products/12862. Needless to say, desired components could be sourced individually more cheaply, but a good example of the possibilities.
So as a first effort to create a educational development platform for these little guys, I have created a PCB design that incorporates the key components, prototyping area for adding the sensors, and a usb charging circuit to allow charging the coin cell. Note that I am just a hacker, not an electrical engineer, and this is totally unverified/untested. But if interested, please improve/correct/modify! https://github.com/erikor/tinybot
Awesome! If you are going to make these, you should definitely post a project and let me know. I haven't looked over your designs yet, but hey, I'm no expert either. I'm a kindergarten teacher.
Ok...project residing at http://hackaday.io/project/2054. (These are a bit larger than yours...3.5 x 4.8 cm. The main size limitation is the size of the coin cell. I could not find a smaller coin cell with anywhere near the capacity that wasn't 3 x more expensive, but the hunt continues). First batch of PCBs is ordered and should arrive in 1-2 weeks!
ZaidPirwani wrote 7 months ago null point
so i have got my motors delivered today - awaiting ATTiny85s now... while I wait,
thinking to over-engineer this:
design a 3d motor/PCB holder and print it with my still experimental 3d printer
design a PCB for the 3d printed PCB holder
OR
just put everything on a vero board with lots of glue and wait till ATTiny85s arrives
Eric wrote 7 months ago null point
This is really great. So half (most?) the learning/fun is putting this together, but I think it might be neat to have a PCB version that plugs into a usb charger (using the pcb itself as the male usb plug, like this: http://www.instructables.com/id/USB-PCB-Business-Card, and using the quite cheap [60 cents] mcp73831 battery charging chip), an upright battery clip, and has a prototyping area that breaks out the attiny pins to further facilitate adding new sensors.
I am working on just such a design and will share as it progresses. Feel free to comment/give input. Maybe I will put what I have so far up on github in the next day or two.
From a young developer standpoint, my vision is that the PCB could be pre-populated with everything except the sensors...then students could focus on programming, and thinking about what sensors/actuators they want to add. They would still get to solder because they would need to add the sensors/actuators.
Older students could just be given the empty PCB and components, and assemble the whole thing.
By the way, the mcp73831 is only available as a surface mount component. But it seems to me the sooner we get young developers over the fear of soldering surface mount, the better. Plus, this helps keep things small. (I am sure there are other battery charge controllers out there that are through hole). Anyway, the current design makes use of SMT MOSFETs already so that bridge has already been crossed.
APBurner wrote 7 months ago null point
What are you using for wheels. I see something red on the end of the shaft but can't tell what it is.
shlonkin wrote 7 months ago null point
Sorry this reply is so late. It is a piece of wire insulation from 0.6mm(22AWG) wire. It just happened to fit perfectly.
so i just ordered
10x ATTiny85s for $10.0 from http://www.aliexpress.com/item/Free-Shipping-10PCS-Original-Integrated-circuit-parts-ATTINY85-ATTINY85-20SU/827307420.html
10x Pager Motors for $8.30 from http://www.aliexpress.com/item/5pcs-4-2V-46000RPM-6x14mm-Coreless-DC-Motor-Strong-magnetic-high-speed-for-helicopter-model-aircraft/1679522733.html
the rest i will be able to buy locally and at cheaper rates, only these 2 I need to import - what about the battery..???
I'm using LIR2032 rechargeable coin cells that I pulled out of some dollar store keychain lights. You could use whatever is most convenient for you.
ianlee74 wrote 7 months ago null point
I love these! In fact, I could see a whole community built around creating infinite variations of these. Please put all your design & source files on GitHub so we can start playing together. Perhaps start a Google Group forum? We're always looking for cheap projects to use for teaching/training kids & user groups and these are just perfect. We can use them as tools for so many different topics including:
- Robotics (of course!)
- Arduino & other programming topics
- PCB design (very small PCB that can be created during a 1 hr demo).
- Motor Control
- Sensors
Perhaps you define a standard size & shape that has to be followed and the challenge then is to see what people can do in that small of a space. Of course, it needs a catchy name too.
Also, how are you currently programming them? Do you remove the ATTiny85 and use a separate programmer or is there something onboard? Is the header for charging the battery?
shlonkin wrote 7 months ago 1 point
If someone had a real interest in this, I would love to support it. I'm often putting together robots that are as simple and cheap as possible. I want to come up with something that even young children could make for just a few dollars(I'm a kindergarten teacher). The great thing about such a simple device is that there is no need for things like design files. As for the code, I would be happy to share, but you have to write your own to understand what's happening.
To program them I have to remove the chip and stick it in a breadboard. I would rather program it in place, but the rest of the circuit would interfere. The two pin header is for connecting the battery. It is a coin cell that is not shown in the pictures because it would cover the whole thing.
srainsdon wrote 7 months ago null point
A wifi finder would be cool
Richard Kutina (kutis) wrote 7 months ago null point
I don't wanna bitch much, but why are all the LED's in those schematics the wrong way around?
ok, the one in the first schematic isn't...
Oh man, you're right. That's embarrassing. That's one danger of hastily copying and pasting.
zakqwy wrote 8 months ago null point
Have you thought about other cheap-o sensors? Maybe an RTD to sense relative temperature and seek hot areas? Or a CdS cell (or other analog light sensor) to avoid/look for light?
shlonkin wrote 8 months ago null point
Yeah, various sensors would be interesting to try. The reason I chose these was so the robots could interact somehow. They can detect the light from other robots. Sadly my life has become far too busy to spend more time on this project, but I may get around to it again someday.
denizece2005 wrote 9 months ago null point
Love these robots. I am just starting out to make my projects and want to give a try to something like these. Would you mind sharing the current software you are using, even if it is incomplete?
shlonkin wrote 9 months ago 1 point
Sure. I'll find some time tonight or tomorrow to clean some up and post it.
shlonkin wrote 9 months ago null point
OK, the code is posted in the log above. Enjoy.
Similar projects
