LED's
10/07/2015 at 21:19 • 0 commentsLED Pin Name PIN_A15 LED[0] PIN_A13 LED[1] PIN_B13 LED[2] PIN_A11 LED[3] PIN_D1 LED[4] PIN_F3 LED[5] PIN_B1 LED[6] PIN_L3 LED[7] -
Clock
10/07/2015 at 21:15 • 0 commentsClock Pin Name PIN_R8 CLOCK_50 -
DE0_Nano.qsf
10/07/2015 at 19:51 • 0 commentsIn the below file the header's GPIO0 and GPIO1 have been given the prefix a and b respectively, but this variable can be freely changed so long as they are not the same.
#============================================================ # Build by Terasic System Builder #============================================================ set_global_assignment -name FAMILY "Cyclone IV E" set_global_assignment -name DEVICE EP4CE22F17C6 set_global_assignment -name TOP_LEVEL_ENTITY "DE0_NANO_Pin_Out" set_global_assignment -name ORIGINAL_QUARTUS_VERSION "12.0" set_global_assignment -name LAST_QUARTUS_VERSION "12.0" set_global_assignment -name PROJECT_CREATION_TIME_DATE "17:09:01 OCTOBER 07,2015" set_global_assignment -name DEVICE_FILTER_PACKAGE FBGA set_global_assignment -name DEVICE_FILTER_PIN_COUNT 256 set_global_assignment -name DEVICE_FILTER_SPEED_GRADE 6 set_global_assignment -name SDC_FILE DE0_NANO_Pin_Out.SDC set_global_assignment -name CYCLONEII_RESERVE_NCEO_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_FLASH_NCE_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DATA0_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DATA1_AFTER_CONFIGURATION "USE AS REGULAR IO" set_global_assignment -name RESERVE_DCLK_AFTER_CONFIGURATION "USE AS REGULAR IO" #============================================================ # CLOCK #============================================================ set_location_assignment PIN_R8 -to CLOCK_50 set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to CLOCK_50 #============================================================ # LED #============================================================ set_location_assignment PIN_A15 -to LED[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[0] set_location_assignment PIN_A13 -to LED[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[1] set_location_assignment PIN_B13 -to LED[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[2] set_location_assignment PIN_A11 -to LED[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[3] set_location_assignment PIN_D1 -to LED[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[4] set_location_assignment PIN_F3 -to LED[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[5] set_location_assignment PIN_B1 -to LED[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[6] set_location_assignment PIN_L3 -to LED[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to LED[7] #============================================================ # KEY #============================================================ set_location_assignment PIN_J15 -to KEY[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to KEY[0] set_location_assignment PIN_E1 -to KEY[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to KEY[1] #============================================================ # SW #============================================================ set_location_assignment PIN_M1 -to SW[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[0] set_location_assignment PIN_T8 -to SW[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[1] set_location_assignment PIN_B9 -to SW[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[2] set_location_assignment PIN_M15 -to SW[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[3] #============================================================ # SDRAM #============================================================ set_location_assignment PIN_M7 -to DRAM_BA[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_BA[0] set_location_assignment PIN_M6 -to DRAM_BA[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_BA[1] set_location_assignment PIN_R6 -to DRAM_DQM[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQM[0] set_location_assignment PIN_T5 -to DRAM_DQM[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQM[1] set_location_assignment PIN_L2 -to DRAM_RAS_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_RAS_N set_location_assignment PIN_L1 -to DRAM_CAS_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_CAS_N set_location_assignment PIN_L7 -to DRAM_CKE set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_CKE set_location_assignment PIN_R4 -to DRAM_CLK set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_CLK set_location_assignment PIN_C2 -to DRAM_WE_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_WE_N set_location_assignment PIN_P6 -to DRAM_CS_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_CS_N set_location_assignment PIN_G2 -to DRAM_DQ[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[0] set_location_assignment PIN_G1 -to DRAM_DQ[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[1] set_location_assignment PIN_L8 -to DRAM_DQ[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[2] set_location_assignment PIN_K5 -to DRAM_DQ[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[3] set_location_assignment PIN_K2 -to DRAM_DQ[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[4] set_location_assignment PIN_J2 -to DRAM_DQ[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[5] set_location_assignment PIN_J1 -to DRAM_DQ[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[6] set_location_assignment PIN_R7 -to DRAM_DQ[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[7] set_location_assignment PIN_T4 -to DRAM_DQ[8] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[8] set_location_assignment PIN_T2 -to DRAM_DQ[9] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[9] set_location_assignment PIN_T3 -to DRAM_DQ[10] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[10] set_location_assignment PIN_R3 -to DRAM_DQ[11] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[11] set_location_assignment PIN_R5 -to DRAM_DQ[12] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[12] set_location_assignment PIN_P3 -to DRAM_DQ[13] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[13] set_location_assignment PIN_N3 -to DRAM_DQ[14] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[14] set_location_assignment PIN_K1 -to DRAM_DQ[15] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_DQ[15] set_location_assignment PIN_P2 -to DRAM_ADDR[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[0] set_location_assignment PIN_N5 -to DRAM_ADDR[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[1] set_location_assignment PIN_N6 -to DRAM_ADDR[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[2] set_location_assignment PIN_M8 -to DRAM_ADDR[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[3] set_location_assignment PIN_P8 -to DRAM_ADDR[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[4] set_location_assignment PIN_T7 -to DRAM_ADDR[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[5] set_location_assignment PIN_N8 -to DRAM_ADDR[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[6] set_location_assignment PIN_T6 -to DRAM_ADDR[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[7] set_location_assignment PIN_R1 -to DRAM_ADDR[8] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[8] set_location_assignment PIN_P1 -to DRAM_ADDR[9] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[9] set_location_assignment PIN_N2 -to DRAM_ADDR[10] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[10] set_location_assignment PIN_N1 -to DRAM_ADDR[11] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[11] set_location_assignment PIN_L4 -to DRAM_ADDR[12] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to DRAM_ADDR[12] #============================================================ # EPCS #============================================================ set_location_assignment PIN_H2 -to EPCS_DATA0 set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to EPCS_DATA0 set_location_assignment PIN_H1 -to EPCS_DCLK set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to EPCS_DCLK set_location_assignment PIN_D2 -to EPCS_NCSO set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to EPCS_NCSO set_location_assignment PIN_C1 -to EPCS_ASDO set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to EPCS_ASDO #============================================================ # Accelerometer and EEPROM #============================================================ set_location_assignment PIN_F2 -to I2C_SCLK set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to I2C_SCLK set_location_assignment PIN_F1 -to I2C_SDAT set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to I2C_SDAT set_location_assignment PIN_G5 -to G_SENSOR_CS_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to G_SENSOR_CS_N set_location_assignment PIN_M2 -to G_SENSOR_INT set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to G_SENSOR_INT #============================================================ # ADC #============================================================ set_location_assignment PIN_A10 -to ADC_CS_N set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to ADC_CS_N set_location_assignment PIN_B10 -to ADC_SADDR set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to ADC_SADDR set_location_assignment PIN_B14 -to ADC_SCLK set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to ADC_SCLK set_location_assignment PIN_A9 -to ADC_SDAT set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to ADC_SDAT #============================================================ # 2x13 GPIO Header #============================================================ set_location_assignment PIN_A14 -to GPIO_2[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[0] set_location_assignment PIN_B16 -to GPIO_2[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[1] set_location_assignment PIN_C14 -to GPIO_2[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[2] set_location_assignment PIN_C16 -to GPIO_2[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[3] set_location_assignment PIN_C15 -to GPIO_2[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[4] set_location_assignment PIN_D16 -to GPIO_2[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[5] set_location_assignment PIN_D15 -to GPIO_2[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[6] set_location_assignment PIN_D14 -to GPIO_2[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[7] set_location_assignment PIN_F15 -to GPIO_2[8] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[8] set_location_assignment PIN_F16 -to GPIO_2[9] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[9] set_location_assignment PIN_F14 -to GPIO_2[10] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[10] set_location_assignment PIN_G16 -to GPIO_2[11] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[11] set_location_assignment PIN_G15 -to GPIO_2[12] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2[12] set_location_assignment PIN_E15 -to GPIO_2_IN[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2_IN[0] set_location_assignment PIN_E16 -to GPIO_2_IN[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2_IN[1] set_location_assignment PIN_M16 -to GPIO_2_IN[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO_2_IN[2] #============================================================ # GPIO_0, GPIO_0 connect to GPIO Default #============================================================ set_location_assignment PIN_A8 -to a_IN[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a_IN[0] set_location_assignment PIN_D3 -to a[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[0] set_location_assignment PIN_B8 -to a_IN[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a_IN[1] set_location_assignment PIN_C3 -to a[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[1] set_location_assignment PIN_A2 -to a[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[2] set_location_assignment PIN_A3 -to a[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[3] set_location_assignment PIN_B3 -to a[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[4] set_location_assignment PIN_B4 -to a[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[5] set_location_assignment PIN_A4 -to a[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[6] set_location_assignment PIN_B5 -to a[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[7] set_location_assignment PIN_A5 -to a[8] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[8] set_location_assignment PIN_D5 -to a[9] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[9] set_location_assignment PIN_B6 -to a[10] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[10] set_location_assignment PIN_A6 -to a[11] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[11] set_location_assignment PIN_B7 -to a[12] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[12] set_location_assignment PIN_D6 -to a[13] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[13] set_location_assignment PIN_A7 -to a[14] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[14] set_location_assignment PIN_C6 -to a[15] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[15] set_location_assignment PIN_C8 -to a[16] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[16] set_location_assignment PIN_E6 -to a[17] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[17] set_location_assignment PIN_E7 -to a[18] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[18] set_location_assignment PIN_D8 -to a[19] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[19] set_location_assignment PIN_E8 -to a[20] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[20] set_location_assignment PIN_F8 -to a[21] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[21] set_location_assignment PIN_F9 -to a[22] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[22] set_location_assignment PIN_E9 -to a[23] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[23] set_location_assignment PIN_C9 -to a[24] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[24] set_location_assignment PIN_D9 -to a[25] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[25] set_location_assignment PIN_E11 -to a[26] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[26] set_location_assignment PIN_E10 -to a[27] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[27] set_location_assignment PIN_C11 -to a[28] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[28] set_location_assignment PIN_B11 -to a[29] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[29] set_location_assignment PIN_A12 -to a[30] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[30] set_location_assignment PIN_D11 -to a[31] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[31] set_location_assignment PIN_D12 -to a[32] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[32] set_location_assignment PIN_B12 -to a[33] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to a[33] #============================================================ # GPIO_1, GPIO_1 connect to GPIO Default #============================================================ set_location_assignment PIN_T9 -to b_IN[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b_IN[0] set_location_assignment PIN_F13 -to b[0] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[0] set_location_assignment PIN_R9 -to b_IN[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b_IN[1] set_location_assignment PIN_T15 -to b[1] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[1] set_location_assignment PIN_T14 -to b[2] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[2] set_location_assignment PIN_T13 -to b[3] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[3] set_location_assignment PIN_R13 -to b[4] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[4] set_location_assignment PIN_T12 -to b[5] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[5] set_location_assignment PIN_R12 -to b[6] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[6] set_location_assignment PIN_T11 -to b[7] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[7] set_location_assignment PIN_T10 -to b[8] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[8] set_location_assignment PIN_R11 -to b[9] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[9] set_location_assignment PIN_P11 -to b[10] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[10] set_location_assignment PIN_R10 -to b[11] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[11] set_location_assignment PIN_N12 -to b[12] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[12] set_location_assignment PIN_P9 -to b[13] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[13] set_location_assignment PIN_N9 -to b[14] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[14] set_location_assignment PIN_N11 -to b[15] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[15] set_location_assignment PIN_L16 -to b[16] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[16] set_location_assignment PIN_K16 -to b[17] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[17] set_location_assignment PIN_R16 -to b[18] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[18] set_location_assignment PIN_L15 -to b[19] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[19] set_location_assignment PIN_P15 -to b[20] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[20] set_location_assignment PIN_P16 -to b[21] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[21] set_location_assignment PIN_R14 -to b[22] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[22] set_location_assignment PIN_N16 -to b[23] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[23] set_location_assignment PIN_N15 -to b[24] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[24] set_location_assignment PIN_P14 -to b[25] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[25] set_location_assignment PIN_L14 -to b[26] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[26] set_location_assignment PIN_N14 -to b[27] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[27] set_location_assignment PIN_M10 -to b[28] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[28] set_location_assignment PIN_L13 -to b[29] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[29] set_location_assignment PIN_J16 -to b[30] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[30] set_location_assignment PIN_K15 -to b[31] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[31] set_location_assignment PIN_J13 -to b[32] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[32] set_location_assignment PIN_J14 -to b[33] set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to b[33] #============================================================ # End of pin assignments by Terasic System Builder #============================================================
