For a good overview from "back then" (in French) : http://frog.isima.fr/copyleft/yann/index.html
Look at all the (still working ?) links and local copies !
- http://frog.isima.fr/copyleft/yann/index.html
- http://frog.isima.fr/copyleft/yann/brochure/f-cpu_desc_fr.html
- http://frog.isima.fr/copyleft/yann/parinux/conf_yg.html
- http://frog.isima.fr/copyleft/yann/19c3-presentation.pdf
- http://frog.isima.fr/copyleft/yann/17c3/conference17C3.html
F-CPU has now evolved and the new "cluster of globules" version is described here.
Related projects: #LRU, #A stack, #YGREC32...
Logs:
1. Overview of the FC1 (F-cpu Core #1)
2. Operating System and Security
3. Instruction packing
4. Pairing and memory read/write
5. Register-Mapped Memory
6. Check-in, Check-out
7. Inter-globule communication
8. Decoupled Globules
9. What can you do with 64 bits wide pointers ?
10. Multicast memory regions
11. Celebration
12. F-CPU as a decent vector processor
13. FC1 : the memo
14. Tagged registers
15. Another cautionary tale... from Apple
16. Tagged Control Stack
17. Pointers and conditions
18. Access rights and capabilities
19. Exceptions
20. Read-as-Zero
21. Register spill
22. SRB : Smooth Register Backup (it was nice)
23. 32 bits
Note for later...
The "LSB" flag (parity) should be complemented by a8, a16, a32 and a64 to check pointer alignment... it's just a NOR of the 1/2/3/4 LSB (respectively)
