imu_test_v2.ino
Arduino for K9 Controller (v2 with Madgwick filtering) per https://github.com/arduino-libraries/MadgwickAHRS/
Updated version, does not send data via xbee until a (any) button is pressed to ensure minimal running when charging via induction
ino - 7.96 kB - 04/04/2016 at 07:09
Download
K9.pdf
K9 Prop diagram that is usually used for external panels/shell creation. Im going to lean towards using the majority the same way except for maybe the bottom panels in the body which do come in a fair bit reducing the amount of interior room for the motors
Adobe Portable Document Format - 74.82 kB - 03/26/2016 at 10:05
Preview
Download
nes_switch_holder v3.stl
File for mounting the 7mm on off push button switch in the NES controller
Standard Tesselated Geometry - 3.79 kB - 03/11/2016 at 07:51
Download
nes controller button cap v2.stl
Button cap for the switch (requires fine printer or some 'modifying')
Standard Tesselated Geometry - 5.94 kB - 03/11/2016 at 07:51
Download
K9Controller_Gerber_Files.rar
Gerber files for custom PCB for NES controller buttons to tie to Arduino FIO
RAR Archive - 63.04 kB - 03/05/2016 at 01:50
Download
