Allowing Extra Spaces
TAIBHSE DESIGNS wrote 01/03/2015 at 17:10 • 1 pointIt would be nice if extra spaces weren't automatically trimmed from the project description (not sure if this effects anywhere else), the reason I say this is because it messes up any ASCII art used to try and add some retro visuals to help describe a project,
I'm not sure about this, but isn't there a code block in the editor you could use?
That option appears when writing logs, It does not seem to appear when writing a projects initial description.
The Project Description has less formatting as we sometimes use it in other places where text only is required (search results and social media). It's kind of meant to be short and sweet. Can you add the art to the details?
I hadn't considered the description section being used that way, that explains the limitation for me and is understandable. To answer the second half, yes I can add it to the description, it also formats better there, thank you for the suggestion.
Great. Glad we found a solution.
makes so much sense now!
