aws_config.hConfiguration for AWS IoTh - 5.07 kB - 08/23/2020 at 06:15 |
subscriber.cppThe source file for PSoC 6 kit. MQTT protocol is implemented and subscribes to AWS IoT Core.cpp - 7.63 kB - 08/22/2020 at 08:42 |
index.jsThis file is for Lambda. Upload it to AWS Lambda after replacing the endpoint with your own.javascript - 5.60 kB - 08/20/2020 at 05:07 |
intents.jsonJSON file for Alexa Skill. You can directly upload this file for the Alexa Skill.JavaScript Object Notation (JSON) - 2.58 kB - 08/19/2020 at 17:41 |
