Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
The new relay system is a classical Accu CPU like some CPUs of the good old 80s. The system was simulated using the game "Logic World", now the real world build has startet!
If you want more information: you find the link to the project homepage on the left. And the complete circuit diagram in the download area. Just for fun.
Overview
The system ist a very simple CPU using an Accu register like CPUs in the 80s.  All mathematical operations are using the Accu, also all store / load operations. And, because it is a "High Performance" relay system, the program counter has its own adder which is only able to add 1 to the program counter.
Here you see an actual picture of the complete system:
The following diagram shows an overview about the system structure:
Note: The PC_HR register is necessary, because I can not write the changed PC based on its own value plus 1 direct into the PC...
One detail is important to understand the design of the system: all registers, which are realized by "self retaining" relays, have to be cleared before any information can be stored, also before the stored information can be changed. Thats the reason why the clock of the system is not an ordinary clock as you know it from digital systems. The clock of this system consists of 4 different pulses:
The control unit of the system is using the instruction register and a state register to select the control lines, a control line timing module is setting the Clear, Input-enable and Output-enable control lines based on the clock information.
And, of course, there is not only a state register...there is also a second state register which is cleared / loaded during cycles 0 and 1. You see this detail in the structure picture and in the circuit diagram. It is the same principle than I have to use for the program counter.
The following table shows the command set of the CPU:
The CPU is able to adress the memory using 3 different adressing modes. a) LD X is loading the Accu with the dataword stored in the adress after the opcode, b) LD M(X) is loading the Accu with the data stored in the memory adress stored after the opcode, and c) LD M(M(X)) is ... yes, indirect adressing. The dataword after the opcode contains the adress where the CPU finds the adress of the dataword that will be stored in the Accu. Is adressing mode c) really necessary? Maybe not. But it makes it easier.
And, as you can see, a CALL / RET set of operations is also avaliable. No, there is no stack realized, only one subroutine level is possible. The return adress is stored in the register SR.
The Simulation using "Logic World"
The following images show the Simulation of the complete system in the game "Logic World". This simulation was used to design the system and to check different design variants.
The relay element:
System overview:
Circuit diagram
The complete system circuit diagram is avaliable in the download section.
The software simulation:
To check if the command set of the CPU is useful, a software simulation using an Excel macro was developed. Using this macro it is possible to step through the code, watch registers and memory and to go forward until a breakpoint. The following picture shows the simulation with an program which multiplies two numbers using shift operations.
CircuitDiagram_120524.pdf
Circuit diagram of the relay computer
Adobe Portable Document Format - 1.91 MB - 05/12/2024 at 13:06
Preview
Download
  • 1 × 24V Relay
  • 1 × Diode
  • Finished the ALU result register
    Peter6 天前 0 comments
    So, here you see the complete ALU result register. It is a 16 bit register. The board with the 17 black relays is the storage board, 16 relays to store the 16 bits (the relays are holding themself active when switched on), one relay to switch off VCC to clear all 16 storage relays. The two other boards are used as an input enable board from the ALU or as an output enable board to the databus...
  • Finished the first part of the ALU result register
    Peter05/11/2024 at 19:41 0 comments
    So, the following little module is able to store a 16 bit value...and will be used as the ALU result register. Two little boards will be next, one as input enable into this register, one as output enable from this register to the data bus.
    You see 17 relays for 16 bit...thats because one relay is used to switch out the 24V to clear the register, this is done by a "Clear" input signal.
  • Finished the first of 3 plates...
    Peter05/06/2024 at 14:14 0 comments
    So, what you see here is the complete adress-module of the relay CPU...the first of three plates is now complete:
    This module is able to hold a 10 bit program-counter, add +1 if necessary, read/write the program-counter to/from the databus, load a adress from the databus into a adress-register and write the program-counter or the adress-register into an adressbus-register...which is connected to the adressbus.
    In the following picture you see the interface:
  • Finished a new register...
    Peter05/05/2024 at 19:57 0 comments
    The following picture shows a new 10 bit register for the adress-module. This register holds the adress if a command wants to access the memory, for example LDA M(X),,,Load the accu with the value stored in adress X. This new register holds the adress, a multiplexer is then switching between the program counter or this new register to copy one of them to the adressbus-register. Thats the way the memory is accessed.
    The register was finished in one day and is tested...so the next days I will integrate it into the adress-module.
  • Tested a 8 bit ALU
    Peter05/01/2024 at 15:34 0 comments
    So, I connected the first 8 ALU boards to implement a 8-bit ALU and tested it. The Shift Left/Right, AND, OR and NOT commands worked perfect. And in the following two pictures you see the calculation of 0x7F + 0x21 = 0xA0 (or: 127 + 33 = 160).
    The first picture shows 0x7F + 0x20 = 0x9F (1001 1111, you see the red LEDs).
    The second picture shows you 0x7F + 0x21 = 0xA0 (1010 0000).
    How fast the calculation realy is will be shown in a video, I plan to finish the 16 bit ALU and measure (and documend) the calculation speed of the 16 bit ALU. I need the calculation time to be able to choose a clock timing for clock 1 of the relay system.
  • Finished the first 8 1-bit ALU boards
    Peter04/22/2024 at 04:36 0 comments
    The first 8 ALU boards are finished, during the next days I will mount them together to a 8-bit ALU and test it. Two 8-bit ALUs are then mounted together to the 16-bit ALU used in the system.
  • Build and tested the first ALU bit...
    Peter04/14/2024 at 08:11 0 comments
    So, the first ALU board is build and tested...and it is working! Now I will start building the remaining 15 boards.
  • ALU PCB finished!
    Peter04/09/2024 at 13:27 0 comments
    For the system I need a circuit with 13 relays for each bit of the ALU...16 times the same circuit! Building this connection by connection wouldn't be a very enjoyable task. So, a friendly colleague offered me to design a PCB out of my circuit diagram. I am truly very grateful to him for it.
    And this is the result. It only took 1 week from the purchase order to the delivery:
  • Finished the accumulator register
    Peter04/09/2024 at 13:10 0 comments
    So, the 16 bit accumulator register, which the register for all mathematical, all store and all load operations, is finished and tested. The next step is to connect the register to the system...
    The 16 black relays with numbers are responsible for storing the bit values (by holding themself in an active state), the black relay without a number releases the VCC (for clearing the stored value) and the orange relays are responsible for Input and Output to/from the databus.
  • Added a little communication PC
    Peter04/09/2024 at 12:46 0 comments
    So, I recently added a little PC just for communication, connected to the arduinos and the logic analyzer. And reachable via remote desktop. The following picture shows you the bottom of the system:
    There you see the memory, the new communication PC and the clock. The yellow marked part is a poti connected to the arduino which is responsible for the clock generation to change the speed of the system.
View all 67 project logs
Ken Yap wrote 02/25/2024 at 23:44 point
👍 I commend you on your persistence with this epic project. I'm sure it will be a classic work when it's done. Looking forward to seeing that.
Peter wrote 02/28/2024 at 20:43 point
Thanks for your encouraging words. My plan is to be finished at the end of 2024...we will see.
