I will be testing out different PCB kits,for quick prototyping before I send it off to OSH
I will host the instructions and descriptions on the OneNote Link. Its easier to manage multiple pages and such on there.
I'm currently testing out the laser printer at 600dpi, need to pump the numbers to 1200dpi and dual layer it. Most likely Ill increase the clearance after I complete the tests
View all 2 project logs
fl@C@
fruchti
Carl Bugeja
Electorials
Yes, delete it Cancel
You are about to report the project "DIY PCB KITs", please tell us the reason.
