When browsing the web, online privacy is extremely important, and using the proxy server is one of the best ways to protect privacy as well as connection security.
Well, the proxy server is a middle-way server that retains the users disconnected from the website they visit. This works like a filter and a firewall that assures only the secured data reach to the users.
And in this way, it protects you from online frauds, unwanted access, and much more. But recently many users confirmed that the proxy won’t turn off on Windows 10.
Commonly the main reason for the proxy won’t turn off is the virus or malware infection. And due to this, you are unable to disable the proxy of your Windows 10 system.
Well, this can be a serious underlying problem and if you are also dealing with a proxy won’t turn off the problem then here it is suggested to follow the solutions given one by one.
How to Fix Proxy Won’t Turn Off in Windows 10?
Solution 1 - Run a Full System Scan
As it is confirmed, the proxy won’t turn off the problem is caused due to malware or virus infection. Well, this is really a worst-case, so here it is suggested to perform a full system scan to remove virus or malware infection.
To perform a full system scan run the Windows 10 inbuilt security software:
- Press the Win key > then type Security
- Then from the Start menu > choose Windows Security
- Next, go to Virus & threat protection > click the Scan options
- Choose the Full scan option.
- Click the Scan now button
- And wait for the scanning process to complete.
Now try to disable the proxy server and check if the issue is resolved. But if not then here it is suggested to follow the next solution.
Solution 2 - Edit your Registry
If the above solution, won’t work for you, then here it is suggested to edit your registry.
Follow the steps to do so:
- Hit the Windows Key + R > in the Run box > type regedit > hit Enter > OK
- Now head to HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings
- Then double-click the ProxySettingsPerUser DWORD and set the value to 1
If in case, the DWORD is not available, then right-click the right window > select New > DWORD (32-bit) Value and name it ProxySettingsPerUser. Then double click on it and set the value to 1.
Well, many users suggest to do the changes in the same location:
- Try changing the ProxyEnable value to 0
- Then change 1 value to 0
- And remove the ProxyOverride key
- Remove ProxyServer key
This worked for many solutions to fix proxy won’t turn off problem.
Solution 3 - Use Settings App
Here it is suggested to use the Settings App, to disable the proxy in Windows 10.
- Press Win + I keys to open the Settings app.
- Then in the Settings app > click on Network & Internet.
- Now scroll down > click on Proxy.
- And on the right side > under the Automatic proxy setup section > turn on the Automatically detect settings
- Next, turn off the Use setup script
Conclusion:
Well the proxy won’t turn off is a very irritating problem, and there are many different reasons responsible for this.
However, there are solutions that work for you to fix the problem and turn off the proxy server connection.
Moreover, if you are able to fix this irritating problem then here it is suggested to start using a trusted VPN service like ExpressVPN. As it is the best option in terms of privacy, security, and also speed up the network connection.
Hope the article is helpful for you.
