The Epson printer error 0x97 is an error code alluding to some issues in the printer hardware. A malfunction in the printer motherboard or some other internal hardware could result in the display of this code. If you are facing this error code, feel free to dial our Epson printer support phone number and our expert will help fix this issue.
For the most part, Epson error code 0x69 happens in the Epson WF3640& 3620 Printer because of the circuit issue that can be related to printing engine or ink framework issue. Thus, you should turn ON the printer and attachment it off abruptly. This interaction ought to be done when your printer is boosting.
