YouTube “Oops! Something went wrong” monkey error troubling you? Here are possible causes & workarounds
Are you struggling with the YouTube Monkey error or 500 Internal Server Error? And wondering how to fix this irritating YouTube error the then this article is for you.
Well, the YouTube 500 internal server error is a common error and many users are found reporting about the error on the forum threads.
As per the users, the error appears while trying to open the YouTube pages 500 Internal Server Error tab opens. And the error message on the tab appears that says:
Sorry, something went wrong. A team of highly trained monkeys has been dispatched to deal with this situation.
Well, it is clear that the error is a server error, so here try the solutions given one by one.
What is YouTube 500 Internal Server Error?
As the error message states the YouTube error is a server and commonly caused when the server is down for a while or the server stopped responding or hacked by others.
Sometimes the server encounters an underlying problem and due to this, YouTube shows the error message with the Monkey showing the error message YouTube 500 Internal server error.
This seems really miserable as many users think they can’t do anything about it, but luckily every problem has a solution.
So, follow the solutions given one by one accordingly and get rid of the error.
How Do I Fix YouTube 500 Internet Server (Monkey) Error?
Well, the common solution to fix the error is to contact the YouTube support team and ask them for help. Is there plenty of users dealing with the problem worldwide?
Apart from that, there are other solutions as well that worked for many users. So, it is worth giving them a try.
Solution 1 - Refresh the page showing error
Well, there are chances that the error lasts temporarily, so here it is suggested to refresh the page. Sometimes the common glitches or bugs get resolved just by refreshing and the error get fixed.
Press CTRL + R keys on your keyboard or and simply press the F5 key a couple of times and try opening the page again.
Check if this works for you to resolve the error but if not then follow the next solution.
Solution 2 - Restart the browser or use another
For many users restarting the browser works to get rid of the YouTube 500 error. So, try restarting the browser, this commonly works when you are dealing with something wrong problem while loading the webpage content.
Moreover, if this won’t do the trick for you then simply run a different browser and try opening the YouTube page and check if the YouTube monkey error appears or not.
Solution 3 – Clear the browser’s Cache
Many users confirmed that them clearing the browser data resolved the YouTube 500 internet server error. Sometimes the corrupted browser cache causes a problem when opening anything on them.
So, try clearing the browser history or the browsing data and check if you are able to resolve YouTube server error 500.
Follow the steps to do so:
- Press Ctrl + Shift + Del key on your Google Chrome browser.
- Now in the open window > choose the Browsing history, Cookies, caches images option & other site data.
- And in the drop-down menu > click Time range > choose All time.
- Click clear browsing data > restart your Chrome browser.
- Now if you are using Firefox browser then click the Open menu button in the left corner.
- Then click on Options for opening another window
- And click on the Privacy option on the left side.
- Then click the Clear Data button for opening the window.
- Choose the Cookies and Cached Web Content options > click the Clear button.
- Hit the Clear data button again.
For Firefox:
Well, the steps to clear cache and browser data are different for every browser here I have given steps for the two hight used browsers the Google Chrome and Mozilla Firefox.
Now try opening YouTube again and check if the issue is resolved or not.
Solution 4 – Check YouTube-Server Status
If the above solutions won’t work for you then there is a possibility that your YouTube server is down. So, to detect and fix 500 Internet Server error, verify the server status.
Well to do so open the DownDetector page for YouTube and check the status to the server. If you find the server issues or the server outage then all you need to do is wait for a day and again check if the server problem is resolved.
Conclusion:
So, this is all about the YouTube 500 Internet server page error or YouTube Monkey error. Well, the error is common and generally appears due to server outages.
Moreover, here I tried to provide valuable solutions for you. Make sure to follow them wisely and resolve the YouTube 500 error with ease.
