**Overview**
It is designed for applications that need low latency, Low throughput data communication in a variety of radio propagation conditions. Due to the unique combination of performance, security and flexibility, the SIM7080G module is ideally suited for M2M applications, such as metering, asset tracking, remote monitoring , E-health etc..
**General Features**
- Supports communication protocols such as TCP/UDP/HTTP/HTTPS/TLS/DTLS/PING/LWM2M/COAP/MQTT
- Supports GNSS positioning (GPS, GLONASS, BeiDou, and Galileo)
- Standard Bee 20PIN GPIO extension header, supports XBee series boards (https://www.digi.com/xbee)
- 2x LED indicators, easy to monitor the working status
- Control Via AT Commands
- Supply voltage range: 2.7V-4.8V
- Operation temperature: -40°C to +85°C
- Dimensions: 27.5 X 24.3 X 3.9 mm
- Weight: 4.4g±0.5g
- SIM Card Size: Nano SIM Card
- Module sole current (VBAT=3.8V):
Idle mode: 10mA
Sleep mode: 1.2mA
PSM mode: 3.2uA
eDRX mode: 0.59mA (eDRX=81.92s)
**Communications Specifications**
- Support Bands:
CAT-M: B1/B2/B3/B4/B5/B8/B12/B13/B14/B18/B19/B20/B25/B26 /B27/B28/B66/B85
NB-IOT: B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B25/B26/B28 /B66/B71/B85
- LTE RF Power Class: 5 (Typ. 21dbm)
- Cat-M: Uplink: 1119Kbps Downlink:589Kbps
- NB-IoT: Uplink: 150Kbps Downlink:136Kbps
**Shipping List**
- 1 X NBIOT_Bee Module
- 1 X SIM antenna
- 1 X GPS antenna
**Development Resources**
