BNO055 Orientation Sensor Datasheet PDF
daenorthughdaenorthugh wrote 02/26/2022 at 07:48 • 2 min read • Like
Product Overview
The BNO055 is a System in Package (SiP), integrating a triaxial 14-bit accelerometer, a triaxial
16-bit gyroscope with a range of ±2000 degrees per second, a triaxial geomagnetic sensor
and a 32-bit cortex M0+ microcontroller running Bosch Sensortec sensor fusion software, in
a single package.
The corresponding chip-sets are integrated into one single 28-pin LGA 3.8mm x 5.2mm x
1.1 mm housing. For optimum system integration the BNO055 is equipped with digital bidirectional I2C and UART interfaces. The I2C interface can be programmed to run with the
HID-I2C protocol turning the BNO055 into a plug-and-play sensor hub solution for devices
running the Windows 8.0 or 8.1 operating system.
This blog will introduce BNO055 systematically from its features, pinout to its specifications, applications, also including BNO055 datasheet and so much more.
BNO055 Features
BNO055 Components
 If you want to know more about BNO055, you can read its datasheet.
Like
