Product Overview
Planar Schottky barrier diodes with an integrated guard ring for stress protection,encapsulated in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic package.
This blog will introduce BAT54C systematically from its features, pinout to its specifications, applications, also including BAT54C datasheet and so much more.
![](https://www.kynix.com/BlogImage-v/ky_bg_head_20220526110409.jpg)
BAT54C Features
- Low forward voltage
- Low capacitance
- AEC-Q101 qualified
BAT54C Pinout
The following figure is the diagram of BAT54C pinout.
![BAT54C Pinout](https://www.kynix.com/editor_u/pdf/20220526/BAT54C-Pinout.jpg)
BAT54C Applications
l Ultra high-speed switching
l Voltage clamping
l Line termination n
l Reverse polarity protection
If you want to know more about BAT54C, you can read its datasheet.
