PCB prototype refers to the trial production of printed circuit boards before mass production. After the electronic engineer completes the PCB circuit design, the process of small batch trial production to the PCB factory is the so-called “PCB prototyping”
The printed circuit board (PCB) is the foundation of every electronic device in the world today. The versatility of high-tech products determines the complexity and high performance of the PCB.
The PCB prototype is an indispensable step before a new product enters mass production. The PCB prototype can correct design defects and improve design performance at a lower cost and faster speed. In addition, it helps to avoid more problems and reduce risks in mass production. Below JHD will walk you through everything you need to know about PCB prototyping.
