Transmit your KiCad Layout to NexPCB for a quick 1 click quote
Have you ever had the trouble of going to the PCB quote page to re-input parameters after Kicad finished the design? We fully understand your feeling, so today we have specially solved this trouble for you.
When you click NextPCB Plug-in button on Kicad, we will export these files to your project:
1. Gerber files in the correct format for production
2. IPC-Netlist file
3. Bom-file that includes all information of components
4. Pick and Place-file used in the assembly
You can click "Save to Cart" to place an order immediately after uploading the files(which usually only takes a few seconds), our engineers will double-check the files before production.
How to Install NextPCB Plugin from Official KiCad Repositories?
Step 1: Click Tools >> Plugin and Content Manager
Step 2: Search “NextPCB” in Filter and Click Install
Step 3: Click Apply Changes
Step 4: Click Close button after the download is complete
How to Install NextPCB Plugin Manually?
You can also download the latest ZIP file from https://gitlab.com/nextpcbofficial/NextPCB-Plug-in-for-Kicad, then open the "Plugin and Content Manager" from the main window of KiCad and install the ZIP file via "Install from File".
Step 1: Download the latest ZIP file
You can also download the latest ZIP file from https://gitlab.com/nextpcbofficial/nextpcb-plug-in-for-kicad-files/-/blob/main/NextPCB-Plug-in-for-Kicad-v0.0.1.zip,then click Download
Step 2: Click Tools >> Plugin and Content Manager
Step 3: Click “Install from File” and then Choose the Download ZIP File
About BOM
All information about components used in your design will be imported. For a faster component quotation, we need the following information:
1. Designator (necessary)
2. Quantity (necessary)
3. MPN/Part Number (necessary)
4. Package/Footprint (necessary)
5. Manufacturer (optional)
6. Description/value (optional)
Now you can place the order directly by NextPCB Plugin-In for KiCad
Usually, it is easier to generate Gerber files using Kicad than other PCB design software. All you need to do is to select the necessary layers and to not forget to generate the DRILL file. Now, let’s get started!
Step1: Open your .kicad_pcb file
After opening your Kicad project - .pro file, you can double-click the .kicad_pcb file or click the “PCBNew” button to open your PCB editor.
Step 2: Click the icon of NextPCB
Click the icon of NextPCB on the top of the window after finishing the design of the layout.
Step 3: You will redirect to PCB quote page after clicking the icon of NextPCB
Step 4: Choose the quantity you need
Step 5: Click “Add to Cart” after confirming your expressway, build time, and Email address
Step 6: Await to Review
Usually, our sales manager will review your order in 30 mins on a business day.
Note:
Our Business Hours
Mon-Fri 1:00AM-10:30AM (UTC)
During non-business hours, we will try our best to respond to you within 24 hours.
Step 6: Proceed to Checkout
Finally, after the review and approval of our sales manager, you can preceed to checkout.
Sponsor of Kicad
As a sponsor of KiCad, we will always support its development.
Note: Thanks to the open source community. Since we are not skilled enough to edit on Github at the moment, any feedback or questions please contact us.
Refer to :https://www.nextpcb.com/blog/NextPCB-Plugin-In-for-KiCad
