< TO "TYPE 3" | <HOME> | TO "TYPE 1">
"Type 4" is used in Laguna 2 / VEL SATIS from 2001 till 2005 (after facelift in 2005 speech was not available anymore)
- It is a sample based system.
- Seperate Box (Uses CAN BUS communication) [contains all languages]
- Languages: French, English, Italian, German, Spanish, Dutch, Portuguese, Turkish, (Japanese, Russian)
P8200006159 / 21654468-8 | January 2002
Voice Synthesizer IC : OKI M6650 (Datasheet)
ROM : UNKNOWN 44Pin Macronix (MX) ... [branded as SAGEM AW1036]
A lot of useful informations HERE
For this system to work you need the "high" version of the cluster (the one with the LCD display). This version of the cluster has the second CAN BUS connector to connect the speech box to. The speech is triggered by several control units over CAN-BUS not just the informations from the cluster like in LAGUNA 1.
