< TO "TYPE 1" | <HOME> | TO "TYPE 3">
"Type 2" is used in Safrane 1 (X54) from 1992 till 2000
- It is a sample based system
- Seperate box (Phase 1 and Phase 2 boxes look the same but have different functions and partnumbers)
(PHASE 1 boxes only contain 1 language and PHASE 2 boxes can be coded to all 5 languages)
ASK ME FOR A DUMP OF THE GERMAN PHASE1 ROM if you want to help finding out how the Audio is encoded on the CHIP!
Controls for both Phases :
PHASE 1:
SYP x54 (Phase 1) | ||
Renault Number | Sagem number | Language |
7700805300 | 21550991-7 (early REV.) | French |
7700805300 | 21552951-7 | French |
7700805301 | English | |
7700805302 | 21552953-8 | German |
7700805303 | Italian | |
7700805304 | 21552955-9 | Spanish |
(1995) SYP_X54 ALLEMAND (German) SAGEM 21552953-8 / 7700805302 D
Synthesizer IC (DSP) : Texas Instruments [D36007NA] (probably a TMS320C1X)
ROM : NEC D23C4001E (DATASHEET)*
Microcontroller : Texas Instruments JL54 CF34086 (seems UNKNOWN to the Internet!!!)
*The Datasheet shows 3 lines that are "User definable" (active on high or low). On the board CE2 is tied to VSS. OE & CE1 are tied together. My guess is that OE & CE1 are active high... Maybe this info will help me later to read the chip...
Look what i have found... The ROM D23C4001E looks suspiciously like a M27C4001 Rom... Maybe its a simple read with my chip programmer... VPP on the 27C4001 is the 12V programming voltage input. As long as i do not try to write to my ROM it should be safe... The expected input on CE2 of the 23C4001 is +5v during normal operation (as we have seen above from the circuit). If OE and CE1 are configured to work like a normal 27C4001 it should just work to read it...
Ok. That was too easy. I just desoldered the ROM and put it into my EPROM reader. I used a preset for "NEC UPD27C4001 @ DIP32" and it read just fine... i guess. The Chip is nearly full of data and i have no idea how its encoded. I tried to import it in Audacity with every available setting. I got no results that sounded like a Voice...
Maybe you have an idea? Contact me.
PHASE 2:
(1999) SYP X54-2 SAGEM 21614185-9/3 / 7700847660
Synthesizer IC (DSP) : Texas Instruments TMS320C14 [D34004FN] (DATASHEET)
ROM : OKI M531602C (DATASHEET)
Its nice that they actually printed the type of DSP on the chip. That gives me a nice clue to what Phase1 is using... The ROM is exactly the same as they used in "TYPE3 (Laguna) Phase 2" (maybe even same content).
Videos:
