![](https://cdn.hackaday.io/images/9705911694603999538.png)
Now, get ready to have extra features and cool DIY-making projects with a brand-new Cricut Joy Xtra machine. The brand has introduced this latest Cricut machine as the second model in the Cricut Joy series. As we know, Cricut Joy was already a hit due to its compact designs and amazing features.
Now, to provide crafters with more hassle-free crafting for small projects, Cricut Joy Xtra comes in a slightly bigger size. Plus, there are many other changes you can see in its features. So, if you are also excited to add this machine to the pack of your Crafting machine, then here is everything you need to know.
Cricut Joy Xtra: An Overview
Cricut Joy Xtra has everything you already saw in its predecessor, Cricut Joy. However, there are some improvements, such as bigger shapes, Print Then Cut features, more cutting power, printer compatibility, and others. Plus, this latest Cricut machine ensures more precision and accuracy while cutting materials. And this machine allows full-color stickers, custom cards, T-shirts, vinyl decals & more.
In addition, crafters can easily connect the machine to their computer or smartphone devices through the Cricut Design Space app. Also, beginner crafters are not required to have much crafting experience to work with Joy Xtra. With the help of this machine, crafters can easily cut, write, foil, and draw. In short, this machine is a power-packed smart cutting option to upgrade from Cricut Joy.
Major Features of Cricut Joy Xtra
Have a look at the features you are going to see in the Joy Xtra machine.
- Joy Xtra comes with the Print Then Cut feature that helps in printing the design and cutting it with the machine.
- This latest Cricut machine also comes in a bigger size than the Cricut Joy.
- And Cricut Joy Xtra is compatible with Cricut Design Space on both computer and mobile phone devices.
- Plus, it comes with Bluetooth compatibility that helps it connect to other devices seamlessly.
- The brand offers best-in-class support service with the purchase of the machine.
- Works with 50+ materials, including all the popular materials like iron-on, vinyl, cardstock, and smart materials.
- Its smart design allows crafters to use the machine without any prior experience with the machine.
- New crafters get free live workshops, online courses & beginner cheat sheets to help them learn the art of DIY crafts.
Specifications of Cricut Joy Xtra
Here is the specification of the Joy Xtra machine that is necessary to know if you are considering buying this machine.
- First, the cutting speed of the Cricut Joy Xtra is 5.65 inches per second.
- This latest Cricut machine dimension is 12.5 in x 6 in x 5.5 in (31.7 cm x 15.2 cm x 13.9 cm).
- The maximum cut size of this machine using the mat is 8.2 in x 11.7 in (20.8 cm x 29.7 cm).
- Plus, the max cut size of smart materials is 8.5 in x 4 ft (21.6 cm x 1.2 m).
- Lastly, the weight of this compact machine is 6 lbs (2.7 kg), which makes it highly portable.
Products That Come With Cricut Joy Xtra
The products Joy Xtra machine includes are listed below:
- Cricut Joy Xtra machine
- Cricut Mini Weeder
- Premium Fine-Point Blade + Housing
- Cricut Joy Fine Point Pen
- Power adapter
- Welcome card
- Materials for a practice cut
- 50 free, pre-designed projects in the companion app
- Free trial subscription to Cricut Access™ (for new subscribers)
Conclusion
Above, you go to the in-depth information about the Cricut Joy Xtra machine, its features, and specifications. Now, you have complete knowledge of what to expect from this latest Cricut machine. Plus, this machine is $50 more than Cricut Joy. For beginners, it is one of the most worthwhile Cricut machines you should have. If you are a hobbyist and already have the Cricut Joy machine, then there is no need to get this machine. However, if pro-crafters, this machine can be a prudent investment.
Frequently Asked Questions
What is Cricut Joy Xtra?
Joy Xtra is the latest Cricut machine and successor of the Cricut Joy. This machine has got some new features other than Cricut Joy features. Plus, the machine got a bigger size than its predecessor and comes with more cutting power. It is the best option for crafters and hobbyists who are looking for a compact Cricut cutting machine. The machine comes with powerful cutting blades that help in cutting, writing, foiling, and drawing.
What is the Price of a Joy Xtra Machine of Cricut?
Cricut Joy Xtra is an amazing compact machine offered by the brand that comes with various unique features. The machine is easy to use and offers the utmost accuracy while cutting. With the help of this machine, crafters can cut more than 50 materials, including Cricut Smart Materials. Plus, the Print Then Cut feature is also included, which was unable in its predecessors. The price of the machine is $199, which is $50 more expensive than the Cricut Joy machine.
What Can I Do With the Joy Xtra Machine?
The Cricut Joy Xtra is a smart machine that comes with various advanced features. Plus, the machine is compatible with a variety of materials like cardstock, iron-on (HTV), and smart materials. And, with the help of the Joy Xtra machine, crafters can make T-shirts, vinyl decals, full-color stickers, custom cards, and many others. So, this machine is the best option as an entry-level DIY cutting machine.
For more information visit: Install Cricut Explore Air 2
Source: Cricut Joy Xtra
