root@UbuntuServer:/home/ymatsui/RPi_Pico_WAV_Player/build# ll
Total 292
drwxr-xr-x 9 root root 4096 11/6 01:34 ./
drwxr-xr-x 9 root root 4096 11/5 18:49 ../
-rw-r--r-- 1 root root 20615 11/6 01:34 CMakeCache.txt
drwxr-xr-x 7 root root 4096 11/6 01:34 CMakeFiles/
-rw-r--r-- 1 root root 176816 11/6 01:34 Makefile
-rw-r--r-- 1 root root 51678 11/6 01:34 RPi_Pico_WAV_Player.elf.map
-rw-r--r-- 1 root root 2593 11/5 18:54 cmake_install.cmake
drwxr-xr-x 6 root root 4096 11/5 18:54 elf2uf2/
drwxr-xr-x 3 root root 4096 11/5 18:54 generated/
drwxr-xr-x 11 root root 4096 11/5 18:54 lib/
drwxr-xr-x 6 root root 4096 11/6 01:34 pico-sdk/
drwxr-xr-x 4 root root 4096 11/6 01:34 pico_extras/
drwxr-xr-x 3 root root 4096 11/5 18:54 pioasm/
root@UbuntuServer:/home/ymatsui/RPi_Pico_WAV_Player/build# cmake ..
PICO_SDK_PATH is /home/ymatsui/pico-sdk
PICO platform is rp2040.
-- The C compiler identification is GNU 12.2.1
-- The CXX compiler identification is GNU 12.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/arm-none-eabi-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/arm-none-eabi-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/arm-none-eabi-gcc
Build type is Release
PICO target board is pico.
Using board configuration from /home/ymatsui/pico-sdk/src/boards/include/boards/pico.h
-- Found Python3: /usr/bin/python3 (found version "3.11.6") found components: Interpreter
TinyUSB available at /home/ymatsui/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040; enabling build support for USB.
BTstack available at /home/ymatsui/pico-sdk/lib/btstack
cyw43-driver available at /home/ymatsui/pico-sdk/lib/cyw43-driver
Pico W Bluetooth build support available.
lwIP available at /home/ymatsui/pico-sdk/lib/lwip
mbedtls available at /home/ymatsui/pico-sdk/lib/mbedtls
Using PICO_EXAMPLES_PATH from environment ('/home/ymatsui/pico/pico-examples')
-- Configuring done (0.9s)
-- Generating done (0.1s)
-- Build files have been written to: /home/ymatsui/RPi_Pico_WAV_Player/build
root@UbuntuServer:/home/ymatsui/RPi_Pico_WAV_Player/build# make
[ 1%] No update step for 'PioasmBuild'
[ 1%] No patch step for 'PioasmBuild'
[ 1%] Performing configure step for 'PioasmBuild'
loading initial cache file /home/ymatsui/RPi_Pico_WAV_Player/build/pico-sdk/src/rp2_common/pico_cyw43_driver/pioasm/tmp/PioasmBuild-cache-Release.cmake
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- The CXX compiler identification is GNU 13.2.0
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Configuring done (0.2s)
-- Generating done (0.0s)
-- Build files have been written to: /home/ymatsui/RPi_Pico_WAV_Player/build/pioasm
[ 2%] Performing build step for 'PioasmBuild'
[ 10%] Building CXX object CMakeFiles/pioasm.dir/main.cpp.o
[ 20%] Building CXX object CMakeFiles/pioasm.dir/pio_assembler.cpp.o
[ 30%] Building CXX object CMakeFiles/pioasm.dir/pio_disassembler.cpp.o
[ 40%] Building CXX object CMakeFiles/pioasm.dir/gen/lexer.cpp.o
[ 50%] Building CXX object CMakeFiles/pioasm.dir/gen/parser.cpp.o
[ 60%] Building CXX object CMakeFiles/pioasm.dir/c_sdk_output.cpp.o
[ 70%] Building CXX object CMakeFiles/pioasm.dir/python_output.cpp.o
[ 80%] Building CXX object CMakeFiles/pioasm.dir/hex_output.cpp.o
[ 90%] Building CXX object CMakeFiles/pioasm.dir/ada_output.cpp.o
[100%] Linking CXX executable pioasm
[100%] Built target pioasm
[ 3%] No install step for 'PioasmBuild'
[ 4%] Completed 'PioasmBuild'
[ 6%] Built target PioasmBuild
[ 6%] Built target my_pico_audio_i2s_audio_i2s_pio_h
[ 6%] No update step for 'ELF2UF2Build'
[ 7%] No patch step for 'ELF2UF2Build'
[ 8%] Performing configure step for 'ELF2UF2Build'
-- The C compiler identification is GNU 13.2.0
-- Check for working C compiler: /usr/bin/cc - skipped
-- Configuring done (0.3s)
-- Build files have been written to: /home/ymatsui/RPi_Pico_WAV_Player/build/elf2uf2
[ 9%] Performing build step for 'ELF2UF2Build'
[ 50%] Building CXX object CMakeFiles/elf2uf2.dir/main.cpp.o
[100%] Linking CXX executable elf2uf2
[100%] Built target elf2uf2
[ 10%] No install step for 'ELF2UF2Build'
[ 10%] Completed 'ELF2UF2Build'
[ 11%] Built target ELF2UF2Build
[ 12%] Building ASM object pico-sdk/src/rp2_common/boot_stage2/CMakeFiles/bs2_default.dir/compile_time_choice.S.obj
[ 13%] Linking ASM executable bs2_default.elf
[ 13%] Built target bs2_default
[ 14%] Generating bs2_default.bin
[ 15%] Generating bs2_default_padded_checksummed.S
[ 15%] Built target bs2_default_padded_checksummed_asm
[ 17%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/main.cpp.obj
[ 17%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/power_manage.cpp.obj
[ 18%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/ui_control.cpp.obj
[ 19%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/UIMode.cpp.obj
[ 20%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/ImageFitter.cpp.obj
[ 20%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/LcdCanvas.cpp.obj
[ 21%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/lcd_background.cpp.obj
[ 22%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/src/stack.c.obj
[ 22%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/TagRead.cpp.obj
[ 23%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/utf_conv.cpp.obj
[ 24%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/UserFlash.cpp.obj
[ 25%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/ConfigMenu.cpp.obj
[ 25%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/src/ConfigParam.cpp.obj
[ 26%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_stdlib/stdlib.c.obj
[ 27%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_gpio/gpio.c.obj
[ 27%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_platform/platform.c.obj
[ 28%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_claim/claim.c.obj
[ 29%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_sync/sync.c.obj
[ 30%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_irq/irq.c.obj
[ 30%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S.obj
[ 31%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_sync/sem.c.obj
[ 32%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_sync/lock_core.c.obj
[ 32%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_sync/mutex.c.obj
[ 34%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_sync/critical_section.c.obj
[ 35%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_time/time.c.obj
[ 36%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_time/timeout_helper.c.obj
[ 36%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_timer/timer.c.obj
[ 37%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_util/datetime.c.obj
[ 38%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_util/pheap.c.obj
[ 38%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/common/pico_util/queue.c.obj
[ 39%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_uart/uart.c.obj
[ 40%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_clocks/clocks.c.obj
[ 41%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_pll/pll.c.obj
[ 41%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_vreg/vreg.c.obj
[ 42%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_watchdog/watchdog.c.obj
[ 43%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_xosc/xosc.c.obj
[ 43%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_divider/divider.S.obj
[ 44%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_runtime/runtime.c.obj
[ 45%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_printf/printf.c.obj
[ 46%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_bit_ops/bit_ops_aeabi.S.obj
[ 46%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_bootrom/bootrom.c.obj
[ 47%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_divider/divider.S.obj
[ 48%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_double/double_aeabi.S.obj
[ 48%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_double/double_init_rom.c.obj
[ 50%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_double/double_math.c.obj
[ 51%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_double/double_v1_rom_shim.S.obj
[ 52%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_int64_ops/pico_int64_ops_aeabi.S.obj
[ 52%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_float/float_aeabi.S.obj
[ 53%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_float/float_init_rom.c.obj
[ 54%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_float/float_math.c.obj
[ 54%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_float/float_v1_rom_shim.S.obj
[ 55%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_malloc/pico_malloc.c.obj
[ 56%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_mem_ops/mem_ops_aeabi.S.obj
[ 57%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_standard_link/crt0.S.obj
[ 57%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_standard_link/new_delete.cpp.obj
[ 58%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_standard_link/binary_info.c.obj
[ 59%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_stdio/stdio.c.obj
[ 59%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_stdio_uart/stdio_uart.c.obj
[ 60%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_stdio_usb/reset_interface.c.obj
[ 61%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_stdio_usb/stdio_usb.c.obj
[ 62%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_stdio_usb/stdio_usb_descriptors.c.obj
[ 62%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040/dcd_rp2040.c.obj
[ 63%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040/rp2040_usb.c.obj
[ 64%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/device/usbd.c.obj
[ 64%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/device/usbd_control.c.obj
[ 65%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/audio/audio_device.c.obj
[ 67%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/cdc/cdc_device.c.obj
[ 68%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/dfu/dfu_device.c.obj
[ 68%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/dfu/dfu_rt_device.c.obj
[ 69%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/hid/hid_device.c.obj
[ 70%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/midi/midi_device.c.obj
[ 70%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/msc/msc_device.c.obj
[ 71%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/net/ecm_rndis_device.c.obj
[ 72%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/net/ncm_device.c.obj
[ 73%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/usbtmc/usbtmc_device.c.obj
[ 73%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/vendor/vendor_device.c.obj
[ 74%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/class/video/video_device.c.obj
[ 75%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/tusb.c.obj
[ 75%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/lib/tinyusb/src/common/tusb_fifo.c.obj
[ 76%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_fix/rp2040_usb_device_enumeration/rp2040_usb_device_enumeration.c.obj
[ 77%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_unique_id/unique_id.c.obj
[ 78%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_flash/flash.c.obj
[ 78%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico/pico-extras/src/rp2_common/pico_sleep/sleep.c.obj
[ 79%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico/pico-extras/src/rp2_common/hardware_rosc/rosc.c.obj
[ 80%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_rtc/rtc.c.obj
[ 80%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_adc/adc.c.obj
[ 81%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/st7735_80x160/lcd.c.obj
[ 82%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/st7735_80x160/my_lcd.c.obj
[ 84%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_spi/spi.c.obj
[ 84%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/fatfs/ff.c.obj
[ 85%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/fatfs/ffsystem.c.obj
[ 86%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/fatfs/ffunicode.c.obj
[ 86%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/fatfs/tf_card.c.obj
[ 87%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/file_menu/file_menu_FatFs.c.obj
[ 88%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/picojpeg/picojpeg.c.obj
[ 89%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/picojpeg/JPEGDecoder.cpp.obj
[ 89%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/LcdElementBox/LcdElementBox.cpp.obj
[ 90%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/audio_init.cpp.obj
[ 91%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/audio_codec.cpp.obj
[ 91%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/ReadBuffer.cpp.obj
[ 92%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/PlayAudio.cpp.obj
[ 93%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/PlayNone.cpp.obj
[ 94%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/PlayAudio/PlayWav.cpp.obj
[ 94%] Building CXX object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_audio/audio.cpp.obj
[ 95%] Building ASM object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_audio/audio_utils.S.obj
[ 96%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico/pico-extras/src/common/pico_util_buffer/buffer.c.obj
[ 96%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/lib/my_pico_audio_i2s/audio_i2s.c.obj
[ 97%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/pico_multicore/multicore.c.obj
[ 98%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_dma/dma.c.obj
[100%] Building C object CMakeFiles/RPi_Pico_WAV_Player.dir/home/ymatsui/pico-sdk/src/rp2_common/hardware_pio/pio.c.obj
[100%] Linking CXX executable RPi_Pico_WAV_Player.elf
/usr/lib/gcc/arm-none-eabi/12.2.1/../../../arm-none-eabi/bin/ld: cannot find -lmy_pico_stdio_usb_headers:
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/RPi_Pico_WAV_Player.dir/build.make:1830: RPi_Pico_WAV_Player.elf] error 1
make[1]: *** [CMakeFiles/Makefile2:2005: CMakeFiles/RPi_Pico_WAV_Player.dir/all] error 2
make: *** [Makefile:91: all] error 2
