What is JRC4558
The JRC4558 is a dual operational amplifier integrated circuit (IC) manufactured by Japan Radio Corporation (JRC), now part of New Japan Radio (NJR). It's a versatile component used in various electronic applications, particularly popular in guitar pedals and audio circuits.
Known for its robust performance, it offers strong input impedance, substantial voltage amplification (with a gain of up to 100dB), and operates within a wide power supply range (from ±4V to 18V). This IC contains two separate op-amps within its 8-pin package and is available in different formats such as DIP (Dual Inline Package) and SOP (Small Outline Package). Its flexibility and reliability have made it a favorite among engineers, hobbyists, and musicians for decades.
What is TL072
The TL072 is a popular dual low-noise JFET-input operational amplifier (op-amp) manufactured by Texas Instruments. It's part of the TL07x series known for its high input impedance, low noise, and wide bandwidth.
Main Differences between JRC4558 and TL072
- Technology:
- JRC4558: Utilizes bipolar technology.
- TL072: Uses JFET (junction field-effect transistor) technology.
- Input Impedance:
- JRC4558: Around 5MΩ.
- TL072: Higher due to JFET input technology, offering increased input impedance.
- Noise Performance:
- JRC4558: Moderate noise performance.
- TL072: Known for low noise, particularly suitable for audio applications requiring minimal interference.
- Voltage Noise:
- JRC4558: Moderate, around 18nV/√Hz.
- TL072: Low, also around 18nV/√Hz.
- Bandwidth:
- JRC4558: Moderate bandwidth, around 3MHz.
- TL072: Wide bandwidth, around 4MHz.
- Slew Rate:
- JRC4558: Slew rate around 1V/µs.
- TL072: Higher slew rate, approximately 13V/µs.
- Input Bias Current:
- JRC4558: Around 200nA.
- TL072: Very low, typically under 10pA due to JFET input.
- Input Offset Voltage:
- JRC4558: Around 1mV.
- TL072: Very low, typically under 3mV.
- Common-Mode Rejection Ratio (CMRR):
- JRC4558: Moderate.
- TL072: Typically higher.
- Power Consumption:
- JRC4558: Generally lower power consumption.
- TL072: Can vary in terms of power consumption.
- Voltage Range:
- JRC4558: ±4V to ±18V.
- TL072: ±3V to ±18V.
- Applications:
- JRC4558: Commonly used in guitar pedals, audio circuits, musical equipment.
- TL072: Often employed in audio equipment, precision circuits, and applications where low noise and high input impedance are crucial.
