Autel MP808BT Pro VS MK808BT Pro
Autel MaxiPRO MP808BT Pro and Autel MaxiCOM MK808BT Pro are the latest automotive diagnostic system tools in 2023. Autel MaxiCOM MK808BT Pro is an upgraded version of MK808BT/MK808/MX808 Scanner. Autel MaxiPRO MP808BT Pro is an upgraded version of MP808/MP808BT/MP808S with 2 year update.
MK808BT Pro belongs to Autel MaxiCOM series, which is positioned for basic and comprehensive diagnosis. MP808BT Pro belongs to Autel MaxiPRO series, which is more comprehensive and efficient in diagnosis. Here we will talk about Autel MP808BT Pro vs MK808BT Pro What is the difference? Which is better and worth buying?
What is Autel MaxiPRO MP808BT Pro Scanner?
Autel MaxiPRO MP808BT PRO is an advanced wireless automotive diagnostic scanner providing specialized diagnostic service for customers. Featuring the powerful Samsung 6-core processor, an 7.0 inch display, and 33ft (10m) wireless communication, based on Android OS, and combined with the best possible coverage of OE-level diagnostics, the MaxiPRO MP808BT PRO scanner performs comprehensive vehicle diagnostics and analysis efficiently.
As Autel newest released scanner in 2023, Autel MaxiPRO MP808BT PRO has achieved a giant leap in vehicle coverage and diagnostic service.
Features of Autel MaxiPRO MP808BT Pro
- Extensive vehicle coverage for more than 80 US, Asian and European vehicle makes
- Exceptional OE-Level system coverage for all electronic systems
- Complete capabilities for codes, live data, active test, ECU information, adaptation, matching, etc.
- Smart AutoVIN technology for identifying vehicles easily
- Automatic system and software updates with real-time push message notifications via Wi-Fi
- Instant remote control tech support anytime, anywhere
- Cloud-based MaxiFix online community provides a vast database of diagnostic and repair tips and proven filed fixes
- Interactive Data Logging sessions enable direct contact with Autel Technical Support for first-hand troubleshooting of diagnostic bugs and errors
- One-stop multitasking designed for ideal management of workshop operations to keep all data files, customer info, and vehicle records well organized
- Convenient data management system for managing internal program applications and reviewing data
What is Autel MaxiCOM MK808BT Pro Scanner?
Autel MaxiCOM MK808BT PRO automotive diagnostic tool , as an advanced version of Autel MX808/MK808BT, based on Android OS and 7.0 inch touchscreen, has the ability to quickly read and clear DTCs for all available modules of the majority of the makes and models on the market. As a pro-grade automotive diagnostic scanner, MK808BT PRO scan tool also provides you with superior special functions, including Oil Reset, EPB(Electronic Parking Brake), SAS (Steering Angle Sensor), BMS (Battery Management System), ABS Brake Bleed and DPF (Diesel Particulate Filter) Regeneration.
Highlights of the Autel MaxiCOM MK808BT Pro
- Android 11.0!
- No IP Restrictions
- All Systems Diagnostic
- Wide Vehicle Coverage
- Support 24 Kinds of Languages
- One Click Wi-Fi Update
- 37+ Service & Maintenance Functions
- Data Log & Remote Help
- 2022 Upgraded Of MK808BT/MK808/MK808S/MX808
- Stable BT Connection, working range up to 30 feet(10m)
Autel MP808BT PRO Helpful Functions For Mechanics Auto Repair Shops
- MaxiFix – Autel MP808BT PRO comes with an online troubleshooter database that provides you with all common DTCs database for most vehicles and allows you to network with other users.
- Remote Desk – MP808BT PRO works with TeamViewer Quick Support to enable you to receive ad-hoc remote support from Autel’s support center, colleagues, or friends, by allowing them to control your tablet diagnostic tool on their PC.
- Shop Manager – MaxiPro MP808BT PRO owns an application that helps you deal with the daily workshop business and improve customer service by helping you manage the workshop information, customer information records, and much more.
- Data Manager –MP808BT PRO Supports to store, print, and review the saved files.
- Academy -Autel MP808BT PRO provides tutorials and technical bulletins written by top-notch technicians and product experts
Autel MP808BT Pro vs Autel MK808BT Pro: Differences and Similarities
From the hardware configuration point of view, MP808BT and MK808BT are the same. Both feature full system diagnostics and maintenance (oil/EPB/SAS/DPF/BMS reset, throttle, TEC learn...)
In terms of software functions, ECU Coding and refresh hidden functions, and software update period, MP808BT Pro has more advantages and more coverage.
Summarize
Autel MP808BT Pro covers all the functions of MK808BT, and also has ECU coding ability and brush hiding function of some cars and VAG guiding function. No matter what model, it can meet the basic car maintenance needs.
