Hey, you just got a new Cricut machine? Well, you must be looking forward to installing it soon, right? If yes, then you also need to know how to complete the Cricut Design Space login. Without a login process, you can’t use Design Space, and you would not be able to take a single cut on your Cricut machine.
I can understand that the setup process can be a little tedious for many people. Therefore, I have made it simple for you in this blog. I will first share my experience setting up my Cricut Maker 3 machine. In addition, I will also tell you how you can create a Cricut account in a few simple steps.
So, let’s dive into this step-by-step guide to setting up the Cricut machine and account creation.
How to Download Cricut Design Space on Your Computer?
Before Cricut Design Space login, you will need to download the Cricut app. Once you complete downloading and installing this app, you can proceed to the next step to create a new Cricut account.
Now, let me show you how you can download this app on your Windows computer:
- First, you will have to open an internet browser.
- Then, search design.cricut.com on your search bar.
- You will move to the page where you have to click on the I agree checkbox to enable a Download button.
- Now, you should hit the Download button to begin downloading the app.
- Once the download is done, you have to double-click on your downloaded file from the Downloads folder.
- After that, you will be asked whether you trust the application; click Yes to download.
- Further, your installation will start.
Finally, when installation is done, you will need to create your Cricut account. To create, move to the next section, where I have explained how to create a Cricut ID.
How to Perform Cricut Design Space Login?
Now, you will have to create your Cricut account. After you get your account created, you have to log in to your account. You will require some Cricut ID and password that we will discuss below:
Below are the steps you need to follow to create or login to your Cricut account:
- First of all, you have to launch the app on your computer and then go to cricut.com/setup.
- Then, you need to click on the Get Started button.
- Now, move to the other screen, where you will enter your first and last name and email address.
- After that, you need to select your country from the drop-down menu, such as the United States, Canada, or the United Kingdom.
- Then, select the check box, and then you need to click on Create User ID.
- A message will pop up on your screen once the account creation process is completed successfully.
- Afterward, click the Continue button.
- Now, you can again open the Design Space and then go to the Cricut account login page to sign in to your Cricut account.
After the Cricut Design Space login, you are ready to set up your Cricut. The following setup steps will be applicable for Windows and Mac both.
How to Setup a Cricut Machine on a Computer?
You need to set up Cricut on a Windows computer by following the steps below:
- First, you need to plug in the machine and power it on.
- Then, take a USB cable to connect to your computer. You can also connect the machine to your computer using a wireless connection such as Bluetooth.
- The third step is to download the Design Space app, which you might have already installed.
- Then, follow the steps shown on your display to select your Cricut and set it up quickly.
Finally, I have explained how to set up your Cricut machine using Design Space.
Conclusion
From the write-up above, you might have learned how to download the Design Space app. After that, in the next section, I have explained everything about the Cricut Design Space login by simply creating the Cricut account first. Lastly, I have also covered the complete machine setup so that you can also do the setup. Follow this easy-to-understand guide stepwise and showcase your creativity in a few simple clicks.
FAQs
Question 1: How do I open Cricut Design Space on my computer?
Answer: To open the Cricut software on your PC, you are required to follow the steps I have explained below:
- First, you have to press the Windows key.
- Then, type Design Space.
- Hit the Enter key on your keyboard.
- Now, you have finally launched the Cricut Design Space on your desktop.
Question 2: Can I create a Cricut Design Space account for free?
Answer: Cricut doesn’t charge its users to create an account. In addition, you don’t need to pay a single penny to use it on your computer. Simply put, the Cricut software is completely free. However, if you want to create your Cricut account, you have to download the Design Space on your computer and then follow the screen prompts to create a new account.
Question 3: Can I create a Cricut account on my phone?
Answer: Obviously, yes, you can have the Design Space account on your phone too. The Cricut Design Space is compatible with several platforms, including Windows, macOS, iOS, and Android. Thus, you can simply download this Cricut app on your Android or iOS phone, including the tablet. After downloading, just launch the app and follow the suggested steps.
Visit: www.cricut.com/setup cricut setup cricut design space setup
