BASIC- and C- Programmable IoT Modules
dmitry-slepovDmitry Slepov wrote 11/09/2016 at 09:08 • 2 min read • Like
These miniature embedded modules are programmable in Tibbo BASIC / Tibbo C and are perfect for IoT and automation applications.
Write your own app using our streamlined Tibbo IDE software!
EM1000 Programmable IoT Module
Our flagship BASIC/C-programmable IoT module. Ethernet, as well as optional Wi-Fi and GPRS connectivity. Four serial ports supporting full-/half-duplex RS232, Wiegand, and clock/data modes.
EM1206 Programmable IoT Module
A miniature, yet powerful BASIC/C-programmable IoT module. Best used with the RJ203 jack/magnetics front-end (shown).
EM500 "MiniMo" Programmable IoT Module
Being the smallest among our BASIC/C-programmable modules, the "vertical slice" EM500 hides behind a standard RJ45 jack and occupies only 18.5x6.5mm (0.63x0.26") of board space.
GA1000 Wi-Fi Add-on Module
Miniature 802.11b/g board, adds Wi-Fi connectivity to compatible Tibbo modules, boards, and controllers. Easy to use, fully integrated, low-power. Requires only 5 I/O lines to control.
RJ203 Jack/Magnetics Front End
RJ45 jack/magnetics front end for use with our EM1206 and EM203 modules. Patented space-saving design.
Like
