Will a mercury relay blow up?
Peter Walsh wrote 12/27/2016 at 02:24 1 point
My hackerspace was throwing out a bunch of capacitors, so I snagged them and now I have a capacitor bank to play with. It holds something like 1700 joules at 200 volts.
I'd like to make a wire vaporizer, and I've been trying to come up with a switch that can handle the enormous instantaneous current that this bank represents. I've already burnt out a 500 amp thyristor in trying.
Would a mercury displacement switch work for this? Such as this one:
http://www.newark.com/durakool/1035a24ac/relay-mercury-spst-no-600vac-35a/dp/24C1554?ost=1035a&DM_PersistentCookieCreated=true&categoryId=800000005435&searchView=table&iscrfnonsku=false
The vaporizer will only exceed the load of the relay for an instant - the *average* power will be much less than the rated relay current, but the *instantaneous* power is much, much bigger.
This would vaporize and ionize some of the mercury in the relay, but I'm thinking that the mercury displacement design, which is encased a steel tube with non-oxidizing atmosphere, wouldn't be damaged by doing this, and the steel tube could withstand the pressure.
Anyone have experience with these switches and could comment?
Will this work?
