Brother PE770 Embroidery Machine Review
embroidery-machineEmbroidery Machine wrote 07/05/2017 at 19:07 • 3 min read • Like
Embroidery is a fun thing to do for some people. We can create beautiful designs either on our clothes, towels, napkins, and many more. In the old days, we did this handcraft manually with our hands and some tools. That way certainly will take time to finish. Now we do not have to do it in such a long time as we have embroidery machine. There have been plenty of them we can choose. One of the machines you can take into consideration is Brother PE770. To know how good it is, you can check out the following review of the machine.
Specifications and Features
The dimensions of Brother PE770 embroidery machine is 21.2x16.9x17.3 inches. The weight of it is 26.6 pounds. This machine has an area specially for embroidery, and the size of the surface is 5x7 inches. It is large enough to put on your creativity freely.
By using this machine, you will be able to use its 136 built-in embroidery designs. Those designs include quilt, floral, and scrollwork patterns. Furthermore, this machine is also equipped with 6 lettering font styles, 10 frame shapes, and 12 border styles.
It uses USB connectivity. It will enable you to store as well as transfer designs. Thus, you will have an access for unlimited design options.
Brother PE770 has a number of features which can ease you in doing embroidery. First, it has a backlit LCD touch screen. This display will be very practical to use for both designing and editing. Second, besides USB port, this machine also has embroidery card slot. Here you can insert a memory card to transfer or store your stitch designs. Third, the automatic needle threader will ease the threading job for you.
Fourth, the auto thread trimmer is able to do lower and upper thread cut by only pushing a single button. Fifth, it has a wide variety of design editing features such as mirror image, increase and decrease design size, rotate, etc. Last but not least, the iBroidery compatibility allows customers to buy any embroidery designs, including licensed characters from Disney, Disney Pixar, and Nickelodeon.
Pros and Cons
This product has several pros which may help you to consider to purchase it, and here some of them.
1. This machine is very easy to use. It is so easy that you will not need to go through its manual book for a long time.
2. It can do threading easily in no time for you.
3. The stitch quality this machine can produce is amazing.
Unfortunately, like any other products, this machine also has its weaknesses, which are.
1. The instruction manual does not include explanation of how to hoop anything apart from the flat-piece fabric or material
2. The display is only available in black and white color.
3. You are unable to add some extra fonts as you want.
Final Verdict
Despite of having several cons, Brother PE770 is still one amazing embroidery machine to have. It has a lot of features which can be very helpful to its users. Most importantly, this is a perfect choice for beginners who are still new in embroidery.
Like
