I receive many questions about decorating and personalizing glasses, especially ones that are dishwasher and microwave-safe. One of the best ways to achieve this is by etching the glass instead of applying vinyl to it.
Wondering how to etch on glass with Cricut? You are in the right place! In this blog, I have provided step-by-step instructions on everything you need to know on this topic. From selecting the right supplies to creating and cutting out the design, applying etch cream, and beyond, I have covered it all.
Follow the steps to add your personalized touch and style to your glassware through etching. Let’s start without further delay.
Tools and Materials for Etching Glass With the Cricut Machine
Similar to other Cricut projects, you need a few supplies to etch glass with Cricut. Here’s what you need to etch glass with a Cricut Maker.
- Cricut Fine-Point blade
- Plain glass bottle
- Cricut cutting machine
- Etching cream
- Cricut weeding tool & scraper
- Rubbing alcohol
- Transfer tape & vinyl (removable or permanent)
- Masking Tape
- Small paint brush
- Gloves & water
- Scissors
- Cut file
Step 1: Create or Upload a Design
To learn how to etch on glass with Cricut, you must create the design in Cricut Design Space. There are some ways to etch glass in the Cricut app, but I prefer to upload the design.
Uploading Images
- Firstly, download an SVG file from the internet and then unzip it.
- Next, start a New Project in Design Space in the top right corner.
- Then, hit the Upload button from the toolbar and select the SVG file.
- Now, select the image type – Complex and tap on the Continue button.
- If you don't want to make changes, choose the upload type – Cut Image, and press Upload.
- Finally, the design will be uploaded and then added to the canvas.
Personalize Your Design
When the design is on the canvas, it is the perfect time to personalize it using the functions in Design Space to learn how to etch on glass with Cricut.
- Measure the size of the bottle you want to etch, then edit and adjust your design size using the top toolbar under Size.
- Next, you will learn how to slice an image on Cricut to create a vinyl stencil. Now, you have to use the Shapes tool to create a square shape and make it larger than the design.
- Open the Slice panel and make a design for your design, as shown in the image below.
Step 2: Cutting the Vinyl
The following are the steps to cut stencil vinyl to learn how to etch on Glass with Cricut.
- Once the design is ready to cut, tap on the Make It button and move to the next screen.
- After that, select the On Mat page, thenclick Continue, and select the stencil option.
- Next, insert the Fine-Point blade and follow the instructions on your screen to load the vinyl onto the machine. Now, press the "C" button to begin cutting.
- Then, weed out the stencil and remove excessive designs that are not needed.
Step 3: Etch Your Glass With the Cricut Vinyl
Let's learn to etch on glass with your Cricut cutting machine, as given below.
- First, place transfer tape over the stencil, burnishing it in all directions.
- Clean the bottle's surface with alcohol, apply the stencil, and remove the transfer tape.
- After that, place the masking tape around the edges of the stencil.
- Apply the etching cream over the stencil and move it for 3 to 5 minutes using a paintbrush.
- Lastly, wash off the etching cream, remove the masking tape, and see the results.
Final Words
The Cricut machine is useful for turning ordinary glass into upcycled glass, offering a cost-effective solution for glassware. To achieve this, you'll need to learn how to etch on glass with Cricut, which is the focus of this blog post. Gather all the essential tools and materials, such as etching cream, a beautiful design, vinyl, and blank glass. The remaining instructions are detailed in this guide.
Frequently Asked Questions
What is the difference between glass etching and engraving?
Etching and engraving are crafting techniques used to decorate timepieces by making desired marks on the material. However, they differ in terms of the depth of the marks. Etching typically creates shallow marks, while engraving results in deeper ones. Both techniques can transform surfaces and bring to life simple to complex designs.
What kind of vinyl do you use for glass etching?
When etching glass, you initially use vinyl to create stencils, thus requiring vinyl. As for the type of vinyl to use, both removable and permanent adhesive options are suitable. However, I prefer removable vinyl for its ease of removal.
What types of glass can I etch with Cricut?
If you intend to etch glass with Cricut, it is important to ensure that your glass object is not tempered glass. What does this mean? Tempered glass is a special type of glass that is resistant to scratches. So, you can use shot glasses, tumblers, certain types of Pyrex, and wine glasses, among others, for etching on colored glass.
Visit: cricut.com/setup cricut design space setup design.cricut.com/setup www.cricut.com setup login install cricut design space app cricut new product setup
