A few days ago, I received a new comment on my previous blog that was on how to setup Cricut Explore Air 2. Then, I decided to write a blog on it. This is an important procedure in the beginning when you have bought a new Cricut cutting machine.
Setting up a Cricut machine can be exciting, but it can also become complex at some point. Even my friend Jacob was excited during the setup of his Cricut Explore. But then he needed my help as he felt he might make some mistakes. Similarly, many of us are afraid of making a mistake when buying a new tool. Therefore, it would be better if we try to get help from someone.
But not everyone is as lucky as my friend, so that is where this blog comes in handy. With this blog tutorial, you will be able to setup your Cricut machine on your computer and mobile.
What Do You Need to Setup Cricut Explore Air 2?
There are sorts of accessories you need before the Cricut Explore Air 2 setup. Ensure you have the following items:
- Cricut machine with all the items available in the box
- A computer, laptop computer, tablet, or smartphone
- Cricut Design Space
- Power cord
- USB cord
- Internet connection
- Cricut ID
- Materials
Now we have all the required items, let’s move to the next section.
How to Setup Cricut Explore Air 2 on Windows/Mac?
The setup process for Cricut is really easy on computers. Be it Windows or Mac, the steps below to set up your Explore Air 2 will be really helpful. Ensure you follow the steps correctly to avoid any errors:
Here are the simplified steps to setup your Explore Air 2:
- Launch the internet browser and then go to cricut.com/setup.
- After that, you will have to download and install your Design Space software to your Mac or Windows.
- Next, install the Cricut Design Space app by following the steps on the display.
- Then, tap on your Cricut cutting machine.
- You should plug your machine into the power source and hit the power button on the Explore Air 2.
- Now, you should follow the steps on your computer to connect it to your Explore Air 2 using Bluetooth.
- Once it is connected, your Cricut Design app will update the cutting machine.
- You have to register your Explore Air 2. For this, you should create a Cricut account and register it.
- Finally, you are ready to perform a test cut on the machine.
How to Setup Cricut Explore Air 2 on Android/iOS?
Now, let’s jump on board into another step where we will setup our cutting machine on a mobile device. Here are simplified steps to setup Explore Air 2:
- First, you will need to establish a connection between your machine and computer using a power cord.
- Subsequent to establishing a connection, you have to make a wireless connection between your Android or iOS phone. Also, the Cricut cutting machine uses Bluetooth.
- After the device is paired up, you should start downloading the Design Space app.
- Then, move to the Google Play Store on Android and Apple Store on iOS.
- From the search bar, you have to search Cricut Design Space.
- Next, you need to click on the Install/Get button to download the app.
- After installing the Cricut app, you should move ahead to create an account.
- Afterward, you have to sign in to a Cricut account following the instructions given on the display.
- Finally, you have completed your Cricut Explore Air 2 setup.
Final Words
Through this blog, I have taught you how to setup the Explore Air 2 model in a few simple steps. Firstly, I discussed the item you will need for this machine setup. The items include Cricut machines and other essential accessories. In the next step, I explained how to setup the model. However, this procedure can also be used to setup other models of Cricut, including Maker, Joy, and Venture.
FAQs
Question 1: Can I connect my Cricut Explore Air 2 to a Mac via Bluetooth?
Answer: Yes, you can. Connecting Cricut with a computer via Bluetooth is an essential step if you want to setup Cricut Explore Air 2. To setup, follow the steps below:
- First, power on the Cricut machine and place your machine within 10 to 15 feet away from the Mac.
- Then, jump to the Apple menu and select System Preferences.
- Further, you need to check for the Bluetooth option.
- Check whether your Bluetooth is on or not. If not, then keep it on and move ahead.
- Hold on for some time until your Mac detects your Explore Air 2. Once you find it, click on it to pair.
Question 2: Which connection method is best for connecting my Cricut to my computer?
Answer: Well, there are two methods that you can use to form a connection between your computer and Explore Air 2 machine. First is a USB wired connection, and second is a Bluetooth wireless connection. Both methods have their own advantage, such as:
- Bluetooth connection: Frees you from those lengthy wires. But it can be trickier due to the long, complex process.
- USB cable: Connecting via USB cable is easy as you just need to plug it into the machine’s and computer’s ports.
Question 3: What could be the problem if my Cricut Explore Air 2 is not connecting to my computer?
Answer: If you are facing this problem again and again, then you should try unpairing and then repairing your Cricut cutting machine. In order to repair it, you have to follow the same method to connect your Cricut via Bluetooth. Just get to the device’s Bluetooth and connect it properly to connect your machine.
Visit: cricut.com/setup
