![](https://cricuthelp.files.wordpress.com/2024/03/comparing-cricut-machines-to-choose-the-right-one-for-you-1.jpg?w=1024)
Maria, my school friend, wants to buy a Cricut machine but doesn't know which one suits her. She read some inaccurate blogs and told me she was confused. If you also want the best Cricut machine but are confused by the many crafting tools options available, then this guide comparing Cricut machines is for you.
I would not ask you to follow this guide blindly; simply read and understand which Cricut machine will fit your needs and budget. I will be comparing the Cricut machines on factors like price, main features, performance, compatibility, and so much more. With over 7 years of experience using Cricut machines, I will also share my personal insights. For more info and details, read this blog post till the end.
1. Cricut Explore 3 vs Cricut Explore Air 2
Cricut gained popularity with the Cricut Explore Air 2 machine, which is known for affordability and versatility. Although it is ideal for beginners, it lacks the versatility of the Maker series. Starting at $179, it cuts over 100 different materials and supports 5 devices. In contrast, the Cricut Maker 3 cutting machine offers better performance with Smart Materials support and a 12-foot cutting capability. It is priced at around $269.99; it supports 6 various devices.
2. Cricut EasyPress 2 vs 3
The EasyPress 2 machine provides manual control on the device, while the EasyPress 3 machine integrates with the Cricut Design app for remote control. Apart from the color, both heat press machines share similar features. However, the EasyPress 3 machine adds a wireless Bluetooth connection and auto temperature & time settings through the Cricut Heat app. Overall, both are suitable choices, but the EasyPress 3 machine offers advanced features for iron-on projects. If you already have one, I wouldn't suggest upgrading.
3. Cricut Maker vs Cricut Maker 3
When comparing Cricut machines for long-term use, the Cricut Maker series stands out. Let's compare the Cricut Maker with the Maker 3 machine.
The Cricut Maker machine offers superior versatility compared to the Explore 3 and Explore Air 2, with the ability to cut more than 300 materials using 13 different tools for a variety of projects like cutting, writing, scoring, debossing, and engraving. It supports Smart Materials and enables making several projects, from paper crafts to complex woodwork.
Cricut Maker 3 shares similarities with the Maker but boasts double the size and speed. With the Maker 3, you can get cutting speeds of up to 8 inches per second, twice as fast as the Maker's 4 inches per second.
While neither the Cricut Maker machine nor the Maker 3 machine comes cheap, with the Maker priced at $329 and the Maker 3 at $399, the investment is worthwhile considering their advanced capabilities and long-term benefits.
4. Cricut Joy vs Cricut Joy Xtra
Did you know you can start creating DIY projects in a small space with minimal investment? The Cricut Joy machine and its upgraded version, the Cricut Joy Xtra machine, can cut over 50 different materials. Comparing Cricut machines will help you find the best fit.
The Cricut Joy cuts up to 4.5 inches by 4 feet, while the Joy Xtra extends to 4 feet by 8.5 inches. Plus, the Joy Xtra supports the Print Then Cut feature, unlike the original Cricut Joy. Prices start at $149 for the Cricut Joy and under $200 for the Joy Xtra.
Frequently Asked Questions
Is there anything better than a Cricut machine?
Remarkably, Cricut offers a wide range of cutting and heat press machines at affordable prices. While no machine is perfect, alternatives to Cricut machines include some Silhouette Cameo models and Brother's crafting machines. However, for a complete crafting experience, opting for a model like the Cricut Maker 3 machine is perfect.
Which Cricut is best for beginners?
When it comes to which Cricut machine you choose, each one is user-friendly and best for crafting; you just need to decide your budget and needs. However, beginners can start their crafting journey with the Cricut Joy, Explore Air 2, or Explore 3 machine. If you are searching to speed up your process, consider the Cricut Maker machine as your companion.
What to know before buying a Cricut?
Before investing in a Cricut machine, it is important to consider the following factors:
- Compatibility: Make sure the crafting machine is compatible with your desired materials and offers different connectivity options.
- Project Type: Decide which Cricut model best suits your needs and budget.
- Budget: Consider a Cricut machine that offers value for money and aligns with your budget while providing long-term benefits.
- Software: Familiarize yourself with the Cricut Design Space and its capabilities to make sure it meets your design needs.
- User Reviews: Research user experiences and reviews from a variety of sources to get info about the machine's performance and reliability.
Final Words
Whether you are considering crafting occasionally or delving into it full-time, comparing Cricut machines before making a purchase is essential. I have provided info about different Cricut models and compared their major features. If you are still unsure about which craft machine to choose, I suggest starting with a less expensive option and upgrading later based on your experience and needs.
Visit: cricut.com/setup www.cricut.com/setup login install cricut design space app cricut.com setup mac design.cricut.com/setup cricut new product setup
