Hey, do you want to download Cricut Design Space for Mac? Look no further than this handy guide. I started using Cricut when I left school. Since then, I have been crafting like crazy. But how to get started with Cricut? Is there any software that we need to use? Yes, there is a free software called Cricut app. You can easily get it from the official Cricut website Cricut.com/setup login.
The best thing about Cricut software is that it works with different operating systems, like Windows, iOS, Mac, and Android. But, I will especially answer the question, how do I download Cricut Design Space on a Mac computer?
Start following the basic steps to download the Cricut app on Mac. Before that, let me show you the necessary system requirements for the Cricut software.
Minimum System Requirements for Cricut Design Space
Do you know why it is essential to know the system requirements before you download Cricut Design Space for Mac? It is important because incompatible software won’t support the app, hindering you from using it. Below are the system requirements for the Cricut app:
- macOS 11 or later
- CPU 1.83 GHz
- 4 GB RAM
- 2 GB Free Disk Space
- USB Port or Bluetooth Connection
- Minimum Display Screen Resolution - 1024px x 768px
- Minimum 2 to 3 Mbps download speed and 1 to 2 Mbps upload speed
Now, you are ready to download and install the Cricut Design app on your Mac system.
How to Download Cricut Design Space for Mac?
Below, I am providing the steps to download your Cricut app so you can start using the Cricut machine easily. The Design Space software is also very important when you have to set up your Cricut machine:
- Power on your computer and launch any browser that you use.
- On the browser search bar, you have to navigate to design.cricut.com.
- Afterward, you have to mark the checkbox to accept Cricut’s terms & conditions.
- Now, the Download button will be activated. Click on it to proceed.
- Next, you will see a page where you will be able to choose a location to save your downloaded file.
- After selecting the desired location, you have to click on the Save tab to begin downloading.
- Once you have downloaded the Design Space, you need to navigate to the Downloads folder.
- Then, double-click on the .dmg file in the Downloads folder.
- On the next window screen, you will have to drag the Cricut icon to the Applications folder icon to start the installation of the Cricut app.
Finally, you have downloaded the application to your Mac system. Now, let’s see which cutting machines are supported with the Cricut app.
Which Cricut Machines Are Compatible With Cricut Design Space?
This is the most important thing to know whether any Cricut machines are compatible with Design Space. Below is the list of machines that are compatible with this software:
- Cricut Explore Air 2
- Cricut Explore 3
- Cricut Maker
- Cricut Maker 3
- Cricut Joy
- Cricut Joy Xtra
All the machines mentioned above are compatible with your Cricut Design app so that you can control your Cricut machine.
How to Setup Cricut Machine Using Design Space?
Now you have downloaded Design Space, use the same app to complete the setup of your Cricut. Below are the steps I have provided to set up Cricut machine on Mac:
- Start your Cricut machine by plugging its cable into the power socket.
- Connect Cricut to the computer with the USB cable or pair it via Bluetooth.
- Since you have already downloaded the Cricut app, open it and follow the steps on the screen.
- By following the instructions on the screen, you will have to create or sign in to your Cricut account.
- After that, choose the machine you want to set up, and thus, the setup is done.
Final Words
I have discussed how to download Cricut Design Space for Mac in this blog. This blog has everything you need to know about Design Space, from system requirements to Cricut setup. This guide is dedicated to beginner crafters who just got their new Cricut machine. They should ensure that this guide has every step explained in a stepwise manner, making it easier to follow.
FAQs
How to fix the issue when Cricut Design Space stops loading after installation?
It might be because you have just downloaded it and haven’t installed it so far. To fix this problem, follow the guide to install the Cricut software. While installing the Cricut app, you need to select your Mac or Windows operating system accordingly. After installation, you need to open the app as you would open any app on your computer.
Why am I repeatedly prompted to download Cricut Design Space for Mac?
After installing the Cricut Design app on your Mac, you simply need to open it like any other application on your computer. But you will need to open it from your computer, not from a website. In other words, if you are visiting a website with a link to Design Space, it will show the options to download and install the Cricut software.
How do I fix if my Cricut Design Space is running slow on Mac?
Before fixing this issue, you have to ensure that you are connected to the internet and also save your work, if any. Now, you have to Force Reload the application to fix the issue. Below are the steps to fix the issue on a Mac computer:
- Go to the Cricut Design app.
- Then, move to the left corner of the screen to select View.
- After that, click on the Force Reload option from the drop-down menu.
