Hey crafters! If you are here to learn how to use a Cricut for shirts, this is the right blog for you. Recently, I finished creating a shirt, so I decided to include it in this blog. It might help crafters understand how to make shirts with Cricut, including Cricut’s use.
I created this shirt for my 8-year-old son, who needed a new T-shirt as a gift. He asked for it and wanted me to make it using my Cricut machine. Also, he is always around whenever I create some crafts on my Cricut. Seeing this, he asked me if I could make a shirt using a Cricut.
When I finally started creating shirts, I noticed that I had run out of many essential supplies. Hence, I needed to buy them. I have already mentioned the essential supplies in this blog for you to consider. Let’s delve into this blog to learn how to use a Cricut machine to create a shirt.
Step 1: Materials and Tools Required
Without essential supplies, you would not know how to use a Cricut for shirts. Therefore, I have mentioned the materials and tools below:
Materials
- Cotton T-shirt
- Iron-on vinyl
Tools
- Cricut machine (You can use Cricut Maker 3 and Cricut Joy LightGrip mat (StandardGrip cutting mat)
- Weeding tool
- Cricut EasyPress
- Cricut EasyPress mat or a folded towel
Tip: You should wash the shirt before applying vinyl on it.
Step 2: Add Your Shirt Design
In this second step, you need to add or upload the shirt design. From Cricut Design Space, you have to find the design that you like.
Didn’t find anything? Chillax! You can create some designs on Design Space. See, if you want to add some text, then I don’t think adding text will be a big deal for you!
All you need to do is go to the Text option and type whatever you would want to add. Here is the design I created for my son’s shirt.
Step 3: Cut the Design on Iron-on Vinyl
Here, I am finally going to show you how to use a Cricut for shirts. Grab your machine and set it up if it is not set up. Afterward, you will need to follow the steps below.
1. Load the Iron-on Vinyl on the Cutting Mat
Here, you can use LightGrip (Blue) cutting mat or StandardGrip (green). Make sure you need a mat that has a little bit of stickiness.
2. Place the Vinyl on the Mat
Now, place the vinyl onto the mat using the brayer tool. Ensure it is adhered properly to the mat. But do you know which side of iron-on vinyl should be up? You need to put the shiny side down on your cutting mat.
3. Start Cutting Your Material
Now, you have to hit the Load button so that you can load the mat into the machine. Next, you can send the design file to your Cricut cutting machine.
To send the file to your machine, follow the steps below:
- First, you have to hit the Make It button.
- After that, you will be on the Prepare Screen. Here, you need to select the Mirror toggle button to turn it on.
- Then, click on the Continue button.
- Further on the Make screen, you have to choose the desired materials that you are going to cut.
- You have to choose Everyday Iron-On from the given Popular Materials list.
- Now, it’s time to cut the design. Load the Fine-Point blade and the mat.
Afterward, you have to click the flashing Go button to begin cutting. Finally, when cutting is done, you have to weed it using a weeding tool or hand.
Once the design is weeded, you have to place it over the shirt.
Note: If using Cricut Explore Air 2, you need to rotate the wheel to Custom, and then you have to select the drop-down menu.
Step 4: Apply the Vinyl
Now, you need to use Cricut EasyPress to transfer the vinyl onto the shirt. For this, you have to setup your workplace. For this, you need to place the EasyPress mat on a flat surface and then place the shirt on it.
Preheat your shirt and then place the material on the shirt. Again, set the recommended temperature for your shirt and place it over it.
Finally, you did it!
This blog might have helped you learn how to use a Cricut for shirts. If yes, start creating it today in no time!
FAQs
Question 1: Why is my iron-on not sticking to my shirt?
Answer: Several reasons can interfere with iron-on’s ability to adhere to your shirts. However, you can easily remove those issues if you want your iron-on to stick properly to your shirt. Read the following reasons to eliminate the problem:
- Ensure the shirt is pre-washed. When you pre-wash, remove dirt or oil easily.
- Check the temperature on Cricut EasyPress and confirm if it is set to the recommended temperature.
Question 2: Which Cricut machine is the best for shirts?
Answer: I would say Cricut Maker 3 is the ultimate cutting machine that will cut all types of vinyl easily to make shirts. Also, the incredible feature of Maker 3 allows users to create extraordinary shirts. This machine cuts things really fast, making your cutting process 2x faster than its predecessor. In a nutshell, a Cricut Maker 3 is the best machine for shirts.
Question 3: How do you get designs for shirts?
Answer: There are many pre-designed projects or templates available on Design Space. You can access them anytime for free. This is the best thing I love about my Design Space. You can just find some of the projects so that you can add them to the Canvas and create them in no time. In short, download the Cricut app and discover the various opinions or designs in one simple click.
Final Words
Through this blog, I have explained how to use a Cricut for shirts quickly. The blog explains two things in one. First, I learned how to make shirts with Cricut and how to use this machine to make extraordinary shirts. I am pretty sure that you can create your own shirts in less time than you think. The process is easy, and I have covered everything in 4 easy steps. So what are you waiting for? Create today and reveal your hidden talent.
Visit: cricut.com/setup www.cricut.com setup login cricut create connect to computer setting up your cricut maker cricut setup create account cricut new product setup cricut setup on computer cricut install setup cricut setup maker create cricut account
