Every user dreams of turning their DIY ideas into reality. All they need to do is complete the Cricut Joy setup on their respective computers and smartphones to make their dreams come true. This smart, compact, and portable cutting machine can effortlessly cut 50+ materials with precision. It comes with built-in Bluetooth technology to connect both devices wirelessly. Users can control this Cricut machine digitally by downloading the Cricut Joy app from the Play Store or App Store.
Besides that, this Cricut cutting machine can repeatedly cut up to 20 feet of Smart Materials and works with the Cricut Design Space app. Users need certain supplies and bundles to create custom-made projects. Keep exploring this blog to get overall details on the machine setup procedure.
Cricut Joy Setup on Your Computer (Windows/Mac)
Before starting any custom-made project using this Cricut model, all users must finish the Cricut machine setup on the computer (Windows/ Mac). Without a doubt, the method of setting up both these machines is simple and takes place within a few minutes. However, the DIYer needs to be very cautious during the setup process. To ease your work, pay special attention to the details below:
Windows
- Begin the process by switching on your Cricut machine using Cricut Joy and placing it within 10-15 feet of your computer.
- Following this, right-click on your mouse and tick the Device Manager option.
- After that, select Bluetooth to allow your computer to communicate with other devices.
- Next, close the Device Manager folder and tap the Settings icon.
- Now, press the Bluetooth & other devices and tick the Add Bluetooth or other device.
- Following this, click Bluetooth and hold on till your computer detects your cutting machine.
- After a few minutes, choose your Cricut model name from the list under the Add a device section.
- Finally, you will learn about the Cricut Joy setup completion process when you get the pop-up message.
Mac
- First, cross-check that both of your devices are on and within 10-15 feet of each other.
- Second, click the Apple menu and tick the System Preferences option.
- Third, choose the Bluetooth feature and press the Turn Bluetooth On (if your device's Bluetooth is off).
- After doing that, you will see Cricut Joy inside the Devices section. Hit the Connect or Pair option.
- During the entire process, your computer and iOS device will be set up together.
Cricut Joy Setup on a Smartphone (Android/iOS)
After finishing the Cricut setup with computers, you can wirelessly set it up with Android & iOS devices. You can refer to the below steps, and all your confusion about setting up smartphones with this Cricut product will come to an end:
Android
- Initiate the process by checking that your cutting machine is on and placed within 10-15 ft.
- After that, switch on your Android device and open the Settings tab on your home screen.
- Now, go to the Bluetooth page and move its toggle to the right side to enable it.
- Next, look for Cricut Joy under the Other Devices row and then tick it.
- After selecting it, you need to wait a few seconds for both devices to set up
- Lastly, you will get a pop-up message when the Cricut Joy setup is done successfully.
iOS
As the earlier part of the blog said, this Cricut model is also compatible with iOS devices. If you've recently bought any device but don't have any clue about how to set them up, then have a look at the below-mentioned steps:
- First, turn on your cut-die machine and check that your mobile device is within a 10-15 ft range.
- After checking that, open your mobile device, go to Settings, and press the Bluetooth feature.
- Next, activate your iPhone Bluetooth and choose Cricut Joy, available in the Other Devices section.
- Following this, you are supposed to hold on until the setup process between the devices continues.
- Finally, you will get a message about your Cricut Joy setup when your iOS device ends.
Conclusion
It doesn't matter which Cricut machine you use for making DIY projects; you first need to set them up with your PCs or mobile devices. Since this was a beginner guide, I tried my best to introduce you to Cricut Joy in-depth. You can make uncountable custom-made crafts within a few minutes for your home decor or business purposes by referencing the above-said process.
Visit: Cricut.com/setup www.cricut.com/setup login cricut design space setup design.cricut.com/setup
