You can take it as a business blog.
12 core indoor optical fiber cable
12芯光缆是内置12根光纤(成分为二氧化硅、石英玻璃)的通信电缆,具有多种结构模型和两种传输模式,是一种应用广泛的通信光缆。
First of all, it has the same transmission speed as light, wide bandwidth and fast transmission speed, and can meet various high-speed communication needs. Its transmission performance is stable and it uses high-quality optical fiber as the transmission medium, which can effectively avoid signal attenuation and interference and ensure the stability and reliability of signal transmission.
Secondly, this kind of optical cable has good confidentiality and strong resistance to eavesdropping, which can ensure the safe transmission of data. At the same time, it has good anti-interference ability. Since the optical fiber is not affected by electromagnetic interference, it can maintain the purity and stability of the signal during use.
Furthermore, the structural design of the 12-core indoor optical cable enables it to have good mechanical properties and temperature characteristics, is resistant to wear, bending, and flattening, and can work stably and reliably in various complex environments. It has good softness and high bending performance, making it convenient for wiring installation in indoor environments. In addition, its material is usually flame retardant, which is not easy to burn and meets indoor safety requirements.
