Are you looking for the steps for the Cricut Mug Press setup? I got you. Through this blog, I will share the easiest way to setup this Mug Press machine. Are you ready to learn it with me? Before we get to the final part, let’s discuss a little bit about a Cricut Mug Press. This machine is excellent for creating custom mugs for your DIY routine. You may be making it for your personal use or to sell it for some profit. But, whatever the reason, you’ll definitely be satisfied with this step-by-step guide to setting up a Cricut Mug Press. So now, let’s get started!
Cricut Mug Press Setup: Unbox, Connection, & Update
If you want to setup your Mug Press, you’ll have to go through a few steps to do it correctly. You’ll have to start with unboxing your press and checking all the necessary items inside its box. So, let’s learn it step by step.
Step 1: Unboxing the Cricut Machine
![](https://cricricutdesigncut.files.wordpress.com/2024/03/cricut-mug-press-unboxing-scaled-1.jpg?w=1024)
The first step is obviously to unbox your machine and check all its important accessories. After checking everything inside the box, you’re good to go. See what you’ll get.
- Power cord
- A warranty manual
- Setup instructions manual
- USB cable
![](https://cricricutdesigncut.files.wordpress.com/2024/03/0_wlbggpc0ecbo2pai.jpg?w=936)
When you’re satisfied with the unboxing part, here you go with the final step. Let’s check them. However, if you find something missing in the box, immediately contact the vendor from whom you purchased it.
Step 2: Connect Your Cricut Machine to a Device
In this step, you need to connect your Mug Press to your device, whether a PC or a smartphone. Let’s see the steps below.
- Once you unbox your machine and check everything inside it, you are good to go.
- In the next step, you need a compatible device like a PC or mobile phone.
![](https://cricricutdesigncut.files.wordpress.com/2024/03/cricut-mug-press-setup.jpg?w=695)
- Now, connect your Mug Press to the power source and turn it on.
- After that, you can connect your machine via a USB cable and turn it on.
- Then, you can visit Cricut’s official website, cricut.com/setup.
- Next, hit the Download button to install the Cricut Mug Press app (Design Space).
- In the following step, click on the Setup or Activate button to begin setup.
- Also, you need to click on the Heat Press.
- Moreover, select your machine.
- Afterward, go with the on-screen prompts to continue.
- When the setup is complete.
This is the easiest way todo Cricut Mug Press setup on your device. Well, if you are setting up your Mug Press for the first time, you’ll need to update its firmware as well. Let’s check it too.
Step 3: Update the Firmware for Cricut Mug Press
So, are you a first time user for Mug Press? If yes, you will have to update the firmware too. Check out the steps below to learn them.
- First of all, you need to connect your Mug Press to the power supply.
- Hit the power button for 5 seconds until you see the orange light flashing.
- After that, you should connect your Mug Press and PC via USB.
- Then, open the Design Space software on your PC.
- Now, you should Sign In to your Cricut account with the right credentials.
- Next, tap on the Design Space Menu and move to the New machine setup.
- Also, go to the Heat Press option and select your machine.
- Afterward, go with all the on-screen prompts.
- Your software will identify your machine in a few minutes.
- The update will start on the following window.
- You can remove the USB cable from the Mug Press and start using your machine.
That’s all for the Mug Press firmware update. Now, the process is complete for your Cricut Mug Press setup. Finally, you’re ready to start using your machine.
How to Set Temperature on Cricut Mug Press?
Once you have setup your Mug Press successfully, you can adjust temperature settings to use it in your projects. While creating a Mug project, it is an important step. Look at the steps below.
- In the first step, head to the Temperature Settings mode and ensure that the machine is ON.
- Then, press the power button for at least ten seconds.
- Now, you will observe the LED light flashing.
- After that, you’ll see the power button flashing in orange.
- Once you find the settings in the LED row, click on the Power button.
- Repeat this process again for just 3 seconds and choose the Settings option.
- Next, you need to disable your Mug Press and close the Temperature Settings.
- At last, you can use your machine for any project.
That’s how you’ll set the temperature settings on a Cricut Mug Press.
Conclusion
In a nutshell, Cricut Mug Press setup is easy and used for your everyday DIY projects. You just need to connect it with a laptop or PC via USB or Bluetooth connection. Moreover, you will need to update the firmware for Mug Press. I have covered all the necessary steps in this blog. So, finally you are ready to use Cricut Mug Press for your projects. Don’t forget to set the temperature settings.
Visit: cricut.com/setup
