Ready to bring your crafting ideas to life with Cricut? If you have been looking for the top rated Cricut machine that is beloved worldwide for its exceptional crafting capabilities, look no further. Welcome to my ultimate guide, where I will not only introduce you to one or two top machines but also provide detailed coverage of more than five models.
For the past six years, I have dedicated myself to crafting full-time and discovered every Cricut model along the way. With this wealth of experience, I am confident that I can provide you with the right tips based on my journey. Also, I will include expert recommendations for each machine. Let's not delay any longer and dive deep into the Cricut machine lineup, starting from the top down.
1. Cricut Maker 3
Many of you are looking to upgrade from your old Cricut machine, while others are beginners starting their crafting journey. For both groups, the top rated Cricut machine I highly recommend is the Cricut Maker 3. This versatile machine meets the needs of both experienced crafters and newcomers.
The Cricut Maker 3 has cutting-edge technology and many features. It is the fastest cutting machine in the Cricut lineup, capable of cutting over 300 materials ranging from thin paper to thick wood and 2.4mm fabric. While it comes with a price tag of around $399, the investment is well worth it in the long run.
Features:
- Cricut Maker 3 comes with 13 tools
- Works with Smart Materials without any cutting mat
- Twice as fast as the Cricut Maker
- Able to cut 12 feet long without a mat
- Automates cutting pressure and speed
- Works with easy-to-use Cricut Design Space
- Provides 10x cutting force
- Offers Bluetooth & USB connectivity
- Capable of cutting, writing, scoring, foiling, debossing, engraving, Print-Then-Cut, and drawing
2. Cricut Explore 3
![](https://cricutdesig.files.wordpress.com/2024/03/cricut-explore-3.jpg?w=1024)
This Explore 3 is a top rated Cricut machine that offers great value and plenty of advanced features. It is a more affordable alternative to the Cricut Maker 3. This updated version of the Explore Air 2 can cut over 100+ materials and works with Smart Materials, allowing cuts up to 12 feet in length without a mat. At just $279, it's a compelling option.
Features:
- Cricut Explore 3 can cut, write, score, draw, and foil.
- It has a Print Then Cut feature.
- Supports both USB and Bluetooth connectivity.
- This machine works with Smart materials.
- An adaptable cutter
- It can be used via Cricut Design Space
- Compatible with 6 different tools
- Able to cut 100+ materials
3. Cricut EasyPress 3
Once you start making projects with the Cricut machine, you'll get to work with HTV and iron on vinyl to create different items like t-shirts, tote bags, coasters, blankets, and more. To use this, you will need a Cricut Heat Press machine. The ideal choice for beginners is the Cricut EasyPress 3, available in two sizes: 12X10 inches and 9 x 9 inches. Prices vary according to size, starting at $149.
Features:
- Built-in Bluetooth connectivity
- Insulated safety base
- Ceramic-coated heat plate
- Auto press function
- Works with the Cricut Heat app
- Compatible with HTV, infusible ink & sublimation
4. Cricut Joy Xtra
![](https://cricutdesig.files.wordpress.com/2024/03/828536-1-cricut-joy-xtra-machine-hero-with-tumblers-0054-edit_copy-1.jpg?w=1024)
The latest top rated Cricut machine, the Cricut Joy Xtra, was launched on September 7, 2023, and has gained popularity due to its advanced features. It is an upgraded version of the Cricut Joy that offers a larger size for DIY projects, up to 8.5 x 11 inches, and compatibility with Smart Materials up to 4 feet long. Priced at $199, it offers additional features like the Print Then Cut feature, making it perfect for sticker making compared to the $149 Cricut Joy.
Features:
- Wider cutting area of up to 8.5 inches
- Capability to cut, write, foil, and draw on 50+ materials
- Print Then Cut feature is included for precise cutting
- Compatibility with foil transfer tools, pens, and blade
- Lightweight and easy to transport
- Bluetooth wireless technology for seamless connectivity
- Free and easy-to-learn Cricut Design Space software
5. Cricut Mug Press
![](https://cricutdesig.files.wordpress.com/2024/03/81ndmxpe7l.jpg?w=1024)
Whether you're planning to start a Cricut business or simply enjoy making mugs or tumblers for your loved ones, a Cricut Mug Press is essential. This machine enables you to easily create unique and memorable designs that offer a niche for your business endeavors. Also, it connects to the Cricut Heat app to ensure the accurate transfer of infusible ink designs onto mugs.
Features:
- Auto-off safety feature for peace of mind
- Enables dishwasher-safe mug creation
- Automatic settings
- Compatible with sublimation for designs
- Progress light provides visual assistance throughout
- Bluetooth connectivity
Final Words
If you are committed to making your dream DIY projects at home, investing in a Cricut machine is worthwhile. I have guided you through the top rated Cricut machine, including three cutting machines, one heat press, and one mug press. Choose the one that fits your style and needs best.
Visit: cricut.com/setup
Source: https://cricutdesig.wordpress.com/2024/03/13/which-is-the-top-rated-cricut-machine-of-2024/
