Viola, all my lovely audiences, I know you must have many questions about where I have been for the past few days. Don’t get anxious; I will answer all your questions. As part of my family, I want to share some good news: I finally bought a Cricut Maker 3 machine. Since then, I have included this Cricut model in my craft room, and I have examined different research papers explaining how to pair Cricut Maker 3 with a smartphone.
This Cricut model is the company’s most powerful cutting machine. To make it work, all DIYers need to do is set it up and pair it with a mobile device. In addition to the pairing process, they must get the Design Space app from Google Play or the App Store. Pay special attention to this guide, as it will share all the info about the easy pairing process.
What Supplies Come With Cricut Maker 3?
Before laying the first stone of pairing Maker 3 with smartphones, all DIYers must buy certain supplies. It will help them form the project as per their choice without facing any issues and within a few minutes. Take a look at the names of the primary crafting items below:
- Cricut Maker 3 cutting machine
- Design Space account
- Cricut cutting mat
- Premium Fine-Point Blade + Housing
- Welcome card & USB cord
- Power adapter
- Cricut Access free subscription
- Materials for a practice test cut
How to Setup Cricut Maker 3 on a Smartphone?
Equally important, if you want to access this Cricut cutting machine with smartphones for crafting purposes, you must set it up. If you are newer and don’t know how to pair Cricut Maker 3 with Android or iOS devices, this section will benefit you. Follow the below tips to finish the setup process:
- You are supposed to start the process by unboxing and placing the machine on an equal-level surface.
- After that, connect the machine power cable to the compatible wall socket and turn on the Cricut product.
- Now, connect the cut-die machine to smartphones via a USB cord or wirelessly via (Bluetooth).
- Further, open the Play Store or App Store and install Cricut Design Space on your respective devices.
- Following this, go to the New Machine Setup page and tick on the Cricut Maker 3 option.
- Now, go through the instructions on your device screen to finish the setup process.
- Conclude the process by doing a material test cut on your cutting machine and check whether it works correctly.
How to Pair Cricut Maker 3 to an Android Device?
Further adding to this blog, all DIYers must know that this Cricut product has built-in Bluetooth technology. It connects with nearby smartphones wirelessly and shares designs during the cutting process. Have a look at the below-said steps to familiarize yourself with how to pair a Cricut Maker 3 with Android devices:
- Take a fresh step by verifying that your cut-die machine is enabled and ranges under 10-15 ft of your mobile phone.
- Moving forward, scroll down your home screen and press the gear icon present at the top right side of the screen.
- Now, hit the Bluetooth icon and turn on your device Bluetooth.
- If the Bluetooth is off, move the toggle to the right side and leave it for a few seconds.
- After a few minutes, you will see a column with the Available Devices name on your device screen.
- Now, press Cricut Maker 3, enter the PIN code (0000) inside the blank, and click OK.
- As a result, your Cricut machine wireless pairing with an Android device will finally be complete.
What’s more important about this Cricut model is its compatibility with all iOS devices. The entire method of pairing up this smart cutting machine with an iPhone can be read below.
How to Pair Cricut Maker 3 to an iOS Device?
While examining this part of the blog, you will be collecting vital steps following which you can effortlessly finish the method of pairing up Cricut Maker with iPhones:
- First, you need to ensure that your Cricut cutting machine is on and within a 10-15 ft range of the device.
- Following this, open the Settings tab > tick Bluetooth, and turn it on (if it is off).
- Afterward, press on your Cricut model, which appears under the Devices section.
- Enter the four-digit PIN code (0000) and press the Pair, and the pairing process will start instantly.
- Finally, your how to pair Cricut Maker 3 with iPhones will be concluded without technical errors.
Conclusion
Overall, setting up Cricut Maker 3 was a child’s play and didn’t require any technical knowledge. The user just needs to be a little cautious while pairing this Cricut model with smartphones via the Bluetooth feature. To finish the process effortlessly, all DIYers must get Cricut design software on their Android and iOS devices. The software supports all the cutting machines and helps the DIYers make various customized projects.
Frequently Asked Questions
Question: How Can I Install Cricut Design Space on Windows?
Answer: Read the below steps and learn about the steps needed to install Design Space on the Windows system:
- First, open the Cricut official website and download the Design Space app file.
- After downloading the file, open it and let it install on your system.
- Now, open the installed app and sign in with your Cricut ID & password.
- Lastly, you can create your account by filling in your full name, country & email ID.
Question: How Do I Pair Cricut Maker 3 to Windows?
Answer: To pair up Cricut cutting machine with a Windows computer, take a look at the below steps:
- Check that both your machines are on and placed within the 10-15 ft range.
- After that, enable your system’s Bluetooth and wait until the scanning process is on.
- Select your Cricut model, enter the PIN code (0000), and tick the Pair option.
- Lastly, your pairing process will come to an end.
Question: Do I Need to Download Cricut App on My Mobile Device?
Answer: All users must download and install the Cricut app on their respective mobile devices. The app allows users to create their favorite designs on a blank canvas using the library and its subscription plan. After successfully connecting, the user can transfer files to the cutting machine before starting the cutting process.
Source: https://cricricutdesigncut.wordpress.com/2024/03/20/how-to-pair-cricut-maker-3-a-beginners-guide/
