![](https://cricutexplores.wordpress.com/wp-content/uploads/2024/03/how-to-set-up-my-cricut-explore-air-2-a-stepwise-guide.png?w=800)
The common question every other DIYer searches for is how to set up my Cricut Explore Air 2. Beyond the shadow of a doubt, this Cricut product makes the user's DIY dreams come true by cutting 100+ different materials. Also, the Cricut Explore Air 2 works with 6 different tools to cut, write, score, and foil on various materials. Whether you are creating cards, T-shirts, or home decor, this Cricut machine makes it easy to go from an idea to I Did It.
Further, when referring to the Cricut machine, one must download and connect the Cricut Design Space app to this Cricut product. Following this, all DIYers need to do is set up and pair both devices for any projects. Keep going with the blog and study the Design Space download, machine setup, and pairing process.
How to Download Cricut Design Space on Mobile Devices?
Before I encountered how to set up my Cricut Explore Air 2 for crafting purposes, I was obliged to install the Cricut app on my mobile devices. To save you time, I have explained the installation process straightforwardly. Stay focused on the given below steps:
Android
Intending to install the Cricut app on Android phones, follow the steps provided below:
- Start by paying a visit to the Google Play Store and navigating to Design Space.
- After getting lucky in finding the app, press the Install option, which appears in the middle of the page.
- Now, the app will start to install, and keep the phone open till the installation is ongoing.
- Afterward, return to your device's home screen and open the app.
- Next, choose Cricut Machine Setup or Sign In and make new designs on the blank canvas.
iOS
Furthermore, this Cricut software is also compatible with iOS devices as an app. To get this free-of-cost app, follow these steps in a systematic order:
- First, open the App Store and type Cricut Design Space inside the Search blank.
- Afterward, hit the Get button and confirm the installation by entering your iTunes password (If asked).
- Now, you need to wait for a few seconds until the app installation is going on.
- After installing the app, click the Cricut Design app and open it.
- To get started, press Machine Setup or Sign In (as per your preference) and start designing your craft on the canvas.
After downloading this Cricut app, it's best to introduce you to setting up this Cricut machine with mobile devices. The details of the machine setup process can be learned from the paragraph below.
How to Set Up My Cricut Explore Air 2 on Android/iOS?
To finish the Cricut Explore Air 2 setup process with Android/ iOS devices, you need to follow the steps given below:
- Initiate the process by plugging your cutting machine into the socket and turning it on.
- After that, pair up your Android or iOS devices with Cricut products via Bluetooth.
- Further, install Cricut Design Space from the App Store or Play Store and launch it.
- Following this, if you already have an account, then sign in or create your account.
- Next, tap the Menu panel and then tick the Machine Setup option.
- At this point, click Cricut Explore Family and then follow the on-screen instructions.
- In the end, you will be notified that the setup has been completed when invited for a material test cut.
These steps should have taught you how to set up my Cricut Explore Air 2 with mobile devices. The DIYer needs to pay special attention while performing the setup process, as it will help them finish the pairing process quickly.
How to Pair Cricut Explore Air 2 to Mobile Devices via Bluetooth?
On the contrary, this Cricut product can pair them wirelessly with Android/ iOS devices. Get to know about the process by referring to the steps below:
Android
Take a quick scan at the steps given below and grab the details about the pairing process:
- Initiate the pairing process by ensuring your respective machine is on and within 10-15 ft of your Android device.
- Next, go to Settings and enable Bluetooth on your device (If it isn't on).
- After that, you will see your device name inside the Available Devices column.
- Then, enter your four-digit PIN code (0000) and click the OK button.
- At last, your wireless pairing process will come to an end.
iOS
See the steps below and learn how to pair this Cricut machine with iOS devices.
- First, you must ensure that your Cricut cutting machine is on and available within 10-15 feet of your iOS device.
- Following this, go to Settings and activate your device Bluetooth by moving the toggle to the right-hand side.
- Select your Cricut machine name from the Devices section and enter the PIN code.
- After that, enter the PIN code and click the Pair option.
- Finally, both of your devices will easily get paired with each other.
Conclusion
You must have understood how to set up my Cricut Explore Air 2. After finishing the download, set up, and pairing process, the user can make various custom-made crafts with this cutting machine. In addition, this Cricut machine is compatible with all PCs and smartphones and works with the Design Space app. Moreover, all users must ensure they take the correct steps during the setup process.
FAQs
Can I Set Up My Cricut Explore Air 2 on My Mobile Device?
Crafters can use Cricut Design Space software to set up their Explore Air 2 with mobile devices. After installing the app, they must turn on their machine and connect it to mobile devices. Then, they must create their respective account by entering the required details or signing in using their Cricut ID and password.
How to Set up Cricut Explore Air 2 on a Desktop?
With the help of the below steps, you can easily set up Cricut Explore 2 with a desktop:
- First, unpack your cutting machine, plug in the power cable & switch it on.
- Next, connect both devices via USB cable or Bluetooth.
- After doing that, download Cricut Design Space & create your account.
- Now, follow the on-screen instructions and wait till the setup process is on.
- Finally, when the setup is finished, you will be invited to cut the material.
How Do I Install Cricut Design Space on My Windows?
By referring to these steps, one can easily install the Cricut software on their Windows:
- First, go to Cricut Design Space's official website Cricut.com setup mac and click Download.
- After that, double-click the file available in the Downloads folder.
- Next, open the installed app and create your account (If you are a new user).
- Finally, you can start working on new projects on the Cricut app.
