I received an interesting email from a reader of my post:
https://teardownit.com/posts/shelly-rgbw2-controller-and-shelly-duo-rgbw-bulb-dangerous-light-pulsations
After having some bloody eyes and reading your article I decided to change the firmware on shelly rgbw2 with ESPHome so I can modify the pwm freq to 1500 Hz like you recommended.
Don't know if placebo or not but I feel better :) .
I can test only with camera from phone with shutter speed at 1/1500 and no flicker (and sub multiples like 1/500).
With PWM freq at 600 Hz I could see flicker on camera at anything above 1/600.
Don't know if this is the same you have tested but I was curious if you can test with a modified Shelly with ESPHome to be able to put higher frequency.
I also don't know if there is a limit on the maximum frequency (the shelly or the COB LED strip it's dimming ) it will work and if is there any benefit in increasing any further.
Thank you for publishing this extensive tests online.
Ciprian
Great news!
I was very interested and read the ESPHome firmware description.
https://esphome.io/components/output/esp8266_pwm.html
Perfect!
I have not previously used ESPHome, but I have been actively using Tasmota for a long time. In this firmware I also found PWM frequency adjustment:
https://tasmota.github.io/docs/Commands/#pwmfrequency
Let's do the tests!
The measurement scheme is simple.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f8204ec56b2d71731e358a_1.jpg)
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f82055c44b3a07dc0f5c05_2.jpg)
1. Old Shelly native firmware.
I found a new old Shelly RGBW2 controller with 2021 firmware in my stock.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f821236520a8150b678a54_3.jpg)
Measurements are taken at 25% brightness. The PWM controller is running at 600 Hz.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f8212884038dee30c77c9a_4.jpg)
2. New Shelly native firmware (20230913-131259/v1.14.0-gcb84623).
The PWM controller operates at 1000 Hz for a brightness of 25%.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f8212d74eaa39564959b06_5.jpg)
3. Tasmota firmware.
Firmware installation is easily done without wires and additional devices using OTA.
Manual: https://github.com/arendst/mgos-to-tasmota
However, I couldn't use this script and found many errors mentioned for this device.
The solution is found right here:
https://github.com/yaourdt/mgos-to-tasmota/issues/102
This is my successful script:
- RGBW2 must be set to Color mode. You do not need to do anything if the device is already in this mode.
- The firmware needs to be downloaded from this link:
http://deviceIP/ota?url=http://dl.nekohell.eu/mg2tasmota-ShellyRGBW2c.zip - Once the WiFi network is configured, you need to use two commands through the Tasmota console (changes will be saved after rebooting or shutting down the device):
SetOption68 1
// The device will switch to 4-channel white mode (if you need it)PWMFrequency 2000
// PWM frequency will increase to 2000 Hz
Configuration for Tasmota and additional information:
https://tasmota.github.io/docs/devices/Shelly-RGBW2/
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f821353750bb405446980b_6.jpg)
I set the PWM frequency by a multiple margin (I was just curious). 4000 Hz.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f8213ada0ebbf122f5a65c_7.jpg)
The optical measuring tool showed an incomprehensible picture for me. But this phenomenon is outside the scope of this post, and I will deal with it later.
![](https://assets-global.website-files.com/6438c93ff266bb9903cab3bc/65f82141d757f8c179e6ee1f_8.jpg)
Conclusions.
- The Shelly device manufacturer can change and does change the PWM frequency in their firmware. I really don't understand their answer about not being able/unwilling to change the PWM frequency to a safe level.
- I am very grateful to Ciprian for the excellent advice. Thank you, Ciprian!
